Abbott Schindl Offline Upload & Sell: Off
p.1 #9 · p.1 #9 · Help me decide please: - RF 1.4x extender or RF 800/f11 IS STM? | |
I’d go for the 1.4X as you’ve already got the 100-500. I’ve been using my 100-500 with both the 1.4X and 1.5X extenders and am quite happy with both, given that you’re aware that the lens gets very long with an extender because it’s got to be zoomed out to at least 300mm to mount the Extender. Like many others, I don’t like having to carry the resulting length around, and also don’t like that the zoom range is reduced. Also, the lens becomes f/14 with the 2X mounted. OTOH, the 800’s pretty long when extended to its working length.
Aside from the physical shortcomings, I’m happy with the image quality the combinations give me with my R5’s. For most birds I try to use 1000s or faster shutter speed and ISO 6400 or slower. I’ve gotten quite a few excellent songbird photos, as well as raptors, waterfowl, shorebirds and other things.
Two things I prefer about this vs the 800 f/11 are its closer minimum focus distance, and that I have the option of shooting the bare lens if I need a faster aperture. I’ve used the mfd quite often with birds at my window feeder, sometimes as close as the lens’ mfd, so I can fill the frame with, for example, a junco’s head and upper body. At the longer end, last night I captured a Great-horned Owlet at dusk using the 1.4X—the bird filled ~1/4 of the frame and had excellent detail at ISO 6400.
Of course in a pinch you could reduce the 800’s MFD by adding an extension tube, but then you reduce the max aperture and lose the ability to focus farther out.
