First day with the A1- lots of noise in BIF
gooby
p.1 #1 · p.1 #1 · First day with the A1- lots of noise in BIF
Amateur hobbyist here. First day with the A1+200-600. Seems like a lot of noise in my BIF photos. Not sure if it's user error or possibly a lighting or distance issue or improper expectations. Shooting shutter priority with auto iso. Cranked up the shutter speed for the swallow's. Thoughts?
  ILCE-1    FE 200-600mm F5.6-6.3 G OSS lens    489mm    f/6.3    1/3200s    1600 ISO    0.0 EV
  ILCE-1    FE 200-600mm F5.6-6.3 G OSS lens    600mm    f/6.3    1/2000s    400 ISO    0.0 EV
  ILCE-1    FE 200-600mm F5.6-6.3 G OSS lens    600mm    f/6.3    1/2000s    1250 ISO    0.0 EV
Jul 09, 2023 at 06:32 PM
George DeCamp
p.1 #2 · p.1 #2 · First day with the A1- lots of noise in BIF
The A1 is a great camera, you need to do some serious reading on what to expect from it. You can't take a photo that's that small in the frame and expect to blow it up to full screen.
Jul 09, 2023 at 06:57 PM
gooby
p.1 #3 · p.1 #3 · First day with the A1- lots of noise in BIF
Thanks. I had seen a few heavily cropped images that looked pristine on here with the A1.
Jul 09, 2023 at 07:32 PM
Imagemaster
p.1 #4 · p.1 #4 · First day with the A1- lots of noise in BIF
Try posting Sony questions on the Sony Forum.
Jul 09, 2023 at 08:17 PM
Karl Witt
p.1 #5 · p.1 #5 · First day with the A1- lots of noise in BIF
Dropped you a PM hoping to help ..
Karl
Jul 09, 2023 at 09:48 PM
louie champan
p.1 #6 · p.1 #6 · First day with the A1- lots of noise in BIF
George and Karl will both give you good advice.
Jul 09, 2023 at 09:52 PM
George DeCamp
p.1 #7 · p.1 #7 · First day with the A1- lots of noise in BIF
Ok good luck with it, I'm sure you'll enjoy it.
Jul 10, 2023 at 08:26 AM
p.1 #8 · p.1 #8 · First day with the A1- lots of noise in BIF
It is the same for every brand Tony and you know this. Why don't you use your extensive talent and knowledge to help somone new?
Jul 10, 2023 at 08:59 AM
Imagemaster
p.1 #9 · p.1 #9 · First day with the A1- lots of noise in BIF
And why don't you butt out? What is the same for every brand
If you have a specific problem with Nikon or Canon gear, you are more likely to get better feedback on the Nikon or Canon Forum. So what is your problem with advising to OP to ask the same question on the Sony Forum?
And I have no knowledge about the A1 that the OP asked about.
Jul 10, 2023 at 02:08 PM
psharvic
p.1 #10 · p.1 #10 · First day with the A1- lots of noise in BIF
Hi Gooby, your expectations are too high. We used to have a very active member who talked about "pixels per duck". An extreme crop on a small bird like the swallow at higher ISO is always going to show a lot of noise and loss of detail. AI Denoise programs can help. For example, if you crop to keep the 3 top ibis and denoise, I think you might have a pretty clean pic.
Jul 10, 2023 at 02:59 PM
cambyses
p.1 #11 · p.1 #11 · First day with the A1- lots of noise in BIF
The noise in the image will be there with any camera, and you can find a lot of controlled test reports online comparing the noise levels among the flagship cameras under various settings, and while Sony A1 may not be the best camera on that metric, it is quite competitive. That being said, with such huge crops, the noise will become a lot more apparent and that again will be true and comparable among all flagship cameras.
Steve Perry's video here is a good explanation on why cropping makes images look more noisy:
Does Cropping Make Your Images Noisier?
And the images you have probably seen with large crops have certainly been through some sort of noise reduction in post...
Edited on Jul 26, 2023 at 03:42 PM · View previous versions
Jul 10, 2023 at 03:51 PM
p.1 #12 · p.1 #12 · First day with the A1- lots of noise in BIF
Cropping and noise. You know this. Don't play dumb!
Yet you know what happens when you crop all the many brands of cameras you own and have owned!
Because I'm tired of watching you abuse people!
You could be nice to people. Try it, you might like it...
Jul 10, 2023 at 04:38 PM
Imagemaster
p.1 #13 · p.1 #13 · First day with the A1- lots of noise in BIF
I know that cropping and the resulting noise is not equal on all cameras. You know that also.
Then try using the HIDE ME button like I have suggested to you many times. Try it, you might like it.
And if you think Try posting Sony questions on the Sony Forum. is abusive, that is your problem.
I guess if I had written Try also posting Sony questions on the Sony Forum. that would have made you happy?
Bye
Jul 10, 2023 at 05:35 PM
p.1 #14 · p.1 #14 · First day with the A1- lots of noise in BIF
And if you think is abusive, that is your problem.
I guess if I had written that would have made you happy?
Bye
Dear Tony:
You create a hostile environment for our new members. Please stop.
Thank you,
Jul 10, 2023 at 08:04 PM
gooby
p.1 #15 · p.1 #15 · First day with the A1- lots of noise in BIF
OK I think I got the hang of it a bit better. Lighting, humidity, and distance were all major factors in the photos on day 1.
First pic and second pic are the same, just cropped and ran through dxo pureraw per suggestion.
That last pic, accidentally left it on shutter priority because they move so fast and took it at 1/5000 but it still came out OK.
  ILCE-1    FE 200-600mm F5.6-6.3 G OSS lens    600mm    f/6.3    1/2500s    500 ISO    0.0 EV
  ILCE-1    FE 200-600mm F5.6-6.3 G OSS lens    600mm    f/6.3    1/5000s    1600 ISO    0.0 EV
Jul 11, 2023 at 08:33 PM
Karl Witt
p.1 #16 · p.1 #16 · First day with the A1- lots of noise in BIF
NICE! HUGE improvement good for you to ask, listen and apply
Karl
Jul 11, 2023 at 09:11 PM
n.v.m.
p.1 #17 · p.1 #17 · First day with the A1- lots of noise in BIF
lmao. hilarious thread.
Jul 12, 2023 at 07:19 AM
gooby
p.1 #18 · p.1 #18 · First day with the A1- lots of noise in BIF
Getting better! I'm thinking my shutter speed was a tad low? I'm also not really sure how to edit well in LR. I used DxO Pureraw to remove noise but I usually just use the presets and auto on LR, so I need to learn more about that.
I just realized that I left my EV on +1.7 accidentally for the Tern... the A1 knob wasn't locked in place and I was wondering why I was getting zebras on the birds. That explains it!
  ILCE-1    FE 200-600mm F5.6-6.3 G OSS lens    600mm    f/6.3    1/3200s    1600 ISO    +1.7 EV
  ILCE-1    FE 200-600mm F5.6-6.3 G OSS lens    600mm    f/6.3    1/2500s    3200 ISO    +1.7 EV
  ILCE-1    FE 200-600mm F5.6-6.3 G OSS lens    600mm    f/6.3    1/500s    250 ISO    0.0 EV
  ILCE-1    FE 200-600mm F5.6-6.3 G OSS lens    600mm    f/6.3    1/500s    100 ISO    0.0 EV
Jul 24, 2023 at 07:31 PM
gooby
p.1 #19 · p.1 #19 · First day with the A1- lots of noise in BIF
Alright I think I got a lot better lately.
  ILCE-1    FE 200-600mm F5.6-6.3 G OSS lens    600mm    f/6.3    1/500s    400 ISO    0.0 EV
  ILCE-1    FE 200-600mm F5.6-6.3 G OSS lens    600mm    f/6.3    1/500s    160 ISO    -1.0 EV
Aug 29, 2023 at 07:24 PM
Tyr-Sog
p.1 #20 · p.1 #20 · First day with the A1- lots of noise in BIF
Nice job on figuring things out! Much improved.
Nice catch with the blood drops and the tern!
Aug 29, 2023 at 07:52 PM
