Canon 100-500 Tripod Ring Mount
EB-1
p.1 #1 · p.1 #1 · Canon 100-500 Tripod Ring Mount
The ring mount collar for my 100-500 is failing and the lens wiggles around even when tight.
For some weird reason I don't see it for sale separately. Is there anywhere to get a new one? I'm not interested in a third party tripod collar because it needs to rotate smoothly from vertical to horizontal. Thanks.
Jun 21, 2023 at 04:58 PM
Sy Sez
p.1 #2 · p.1 #2 · Canon 100-500 Tripod Ring Mount
" To order an replacement part, please call 1-800-828-4040. The hours of operation are 9:00 A.M. to 8:00 P.M. EST from Monday to Friday. When calling, speak the term "order parts" when the speech routing system asks the reason for your call. You will immediately be routed to the Parts Desk for assistance"
https://support.usa.canon.com/kb/index?page=content&id=ART121398
Some Used one's on E-bay:
https://www.ebay.com/itm/175723836176?chn=ps&_trkparms=ispr%3D1&amdata=enc%3A1YBXQEbzEQsKpbwNjAiQV0Q79&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&mkscid=101&itemid=175723836176&targetid=1587268787897&device=c&mktype=pla&googleloc=9011703&poi=&campaignid=19894961968&mkgroupid=148855406073&rlsatarget=pla-1587268787897&abcId=9307911&merchantid=115355888&gclid=CjwKCAjwv8qkBhAnEiwAkY-ahiZTfLfka8xYiDciWMV8eOq6ePclW4m-hfrTi3YZrCQKWs0YjbiePhoCJIgQAvD_BwE
https://www.ebay.com/itm/175704509348?chn=ps&mkevt=1&mkcid=28&srsltid=AR57-fABpoXCquRFt1Mrs_maO2vMUW_9biMTypZC-U8i4ICj2DM6h4d-sDg
Jun 21, 2023 at 05:08 PM
thedutt
p.1 #3 · p.1 #3 · Canon 100-500 Tripod Ring Mount
I have an spare one in case you are not able to find it elsewhere. ( I totaled my lens on a trip and ended up buying a new one. Havent gotten around to listing parts for sale).
Jun 22, 2023 at 09:47 AM
EB-1
p.1 #4 · p.1 #4 · Canon 100-500 Tripod Ring Mount
Canon wants $198 for it. It's ridiculous that the ring mount clamping system is so poorly designed. Even so a few parts could be replaced to repair it.
Jul 12, 2023 at 02:28 PM
Choderboy
p.1 #5 · p.1 #5 · Canon 100-500 Tripod Ring Mount
Try asking about cost for a replacement for 100-400 II. I was quoted over one third the cost of new lens and that was ring only, not the foot, not including labour cost.
Jul 12, 2023 at 07:35 PM
EB-1
p.1 #6 · p.1 #6 · Canon 100-500 Tripod Ring Mount
Both of my 100-400 IIs have broken lens hoods, but the tripod collars are fine. I did add a bit of Loctite to the tiny screws years ago. I replaced the Canon feet years ago with the low profile Kirk A-S compatible feet.
Jul 13, 2023 at 11:54 AM
AmbientMike
p.1 #7 · p.1 #7 · Canon 100-500 Tripod Ring Mount
I'd probably put some kleenex or something in there to make it tight. Which I'm sure is the "wrong" thing to do
Jul 13, 2023 at 12:24 PM
Zenon Char
p.1 #8 · p.1 #8 · Canon 100-500 Tripod Ring Mount
That is because you can't buy it at Lowe's.
Jul 13, 2023 at 01:10 PM
EB-1
p.1 #9 · p.1 #9 · Canon 100-500 Tripod Ring Mount
I wanted to people to know the cost if they are curious. If I had lost or physically damaged the tripod ring mount, I would not be complaining so much. However, it deteriorated under normal use in less than two years (about 5 weeks in the field). The design is rubbish.
Jul 13, 2023 at 01:18 PM
Sy Sez
p.1 #10 · p.1 #10 · Canon 100-500 Tripod Ring Mount
14 verified user's claim "this one" is better than Canon's?
May be worth a try--send it back if not satisfied.
https://www.amazon.com/iShoot-Compatible-100-500mm-4-5-7-1L-Arca-Swiss/dp/B09NPMSHLS/ref=asc_df_B09NPMSHLS/?tag=hyprod-20&linkCode=df0&hvadid=647178227994&hvpos=&hvnetw=g&hvrand=6600077566073228703&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9011703&hvtargid=pla-1754837256942&psc=1&gclid=CjwKCAjw5MOlBhBTEiwAAJ8e1mmmAkIx1U2nFAbxCyLi_-DupGEeksu-8hbHd3mzEhEWlb9yywgAHBoCve0QAvD_BwE
Jul 14, 2023 at 01:31 PM
EB-1
p.1 #11 · p.1 #11 · Canon 100-500 Tripod Ring Mount
I have several of the iSHOOTs (including the RF 100-500 and RF 70-200/4) and the quality is lacking. Even though the RF 100-500 ring mount holds the lens securely enough the rotation is not so smooth when partly loose. My copy of the ring mount for the RF 70-200/4 is worse. It doesn't quite fit right for the various switch cutouts, plus the tightening process literally makes squeaking/grinding sounds and the threads were oily. Despite having an A-S base, both of them need an A-S plate if you want proper balance since the length and position are insufficient.
I give the iSHoots some credit for trying, but it's like they are not actually photographers using the products in the field.
Jul 14, 2023 at 01:41 PM
Jesse Evans
p.1 #12 · p.1 #12 · Canon 100-500 Tripod Ring Mount
Sounds like iShoot has some quality control issues. My iShoot for the 70-200 f/2.8 is made quite well and fits like the original. Somewhat unsurprising that the more complex shapes of the 100-500 and 70-200/4 have more issues though.
Jul 14, 2023 at 01:56 PM
ramage
p.1 #13 · p.1 #13 · Canon 100-500 Tripod Ring Mount
Not the "wrong" thing to do in my mind.
I saw one too many stories about the collar slipping so I cut up an old lens cloth and lined the collar before tightening down. I did this the day I got the lens and have not had any issues, I do not ever remove the collar so I suppose that is also helping
This really is a bad design on Canon's part, oddly my RF 70-200 2.8 has the same basic design but has been solid.
Jul 14, 2023 at 05:52 PM
Choderboy
p.1 #14 · p.1 #14 · Canon 100-500 Tripod Ring Mount
1 layer of electical tape on the barrel should be enough. Decent quality tape will last and ooze less adhesive with heat over time. When tripod mounted, switching from landscape to portrait is usually done with portrait in the same position. So you can make the join (or gap) in the tape where the join in the collar will not be, so less chance of it lifting the tape.
I have done this with EF collars. I had 2 (or 3) EF collars that needed this.
Jul 14, 2023 at 08:10 PM
EB-1
p.1 #15 · p.1 #15 · Canon 100-500 Tripod Ring Mount
I decided to buy a new Canon one. We'll see how long it lasts.
Jul 14, 2023 at 10:21 PM
fgphoto
p.1 #16 · p.1 #16 · Canon 100-500 Tripod Ring Mount
I have the iShoot for the RF 70-200 2.8 and the 100-500 and they are much more useful than the Canon ones because of the built-in dovetail. I have had no issues with either of mine and would happily order them again.
Jul 17, 2023 at 10:31 AM
Susurrus
p.1 #17 · p.1 #17 · Canon 100-500 Tripod Ring Mount
I will add a positive review for the iShoot. Also, I replaced the foot with a Desmond 115 plate (needed a few longer screws from the hardware store), so I get the added benefit of arca swiss mount without stacked plates, and a long handle. It's still not secure if you loosen it enough to rotate while shooting, but when tight, it's very secure, and I trust it to carry by a D-loop threaded in (another benefit of the longer plate is that with the d-loop there's still real estate for sliding onto a tripod or ground pod).
Jul 24, 2023 at 01:20 PM
