Ricoh GR3 Issue
M_Wales
p.1 #1 · p.1 #1 · Ricoh GR3 Issue
my 3 comes on, but the screen is blank like it not looking through the lens. The screen works fine with the menu button.. When the shutter button is pressed the shutter does not open and close but it starts counting like it taking a long exposure.
I have reset it many times hoping to bring it back to life.
Anyone have an idea of what I can try or what the problem may be?
Thank you
May 25, 2023 at 11:12 AM
Andrew Johns
p.1 #2 · p.1 #2 · Ricoh GR3 Issue
Hmm, thatís interesting. Have you cycled through the display button options? The GR has a screen off setting for shooting with an external optical viewfinder. Obvious, but double check the self timer and interval timer settings.
May 25, 2023 at 12:45 PM
M_Wales
p.1 #3 · p.1 #3 · Ricoh GR3 Issue
I did check those before and just rechecked to make sure and everything is off. It feels like the leaf shutter has just died. When I half press the shutter button nothing happens at all..
Thanks for posting
May 25, 2023 at 07:09 PM
TENOG
p.1 #4 · p.1 #4 · Ricoh GR3 Issue
Have you tried removing the battery, then replacing it and restarting? That reboot seems to solve a lot of weird problems in cameras.
May 25, 2023 at 10:33 PM
M_Wales
p.1 #5 · p.1 #5 · Ricoh GR3 Issue
Tried 3 batteries and plugging it in to USB power and charging the batteries also.
Thank you
May 26, 2023 at 06:06 AM
markhout
p.1 #6 · p.1 #6 · Ricoh GR3 Issue
Thank you
The 'reset' is more like remove battery, leave it out for a night, switch on without battery, put battery back in, switch on with battery...
May 26, 2023 at 08:02 AM
