Will & Wade
Majestictone
p.1 #1 · p.1 #1 · Will & Wade
Good Evening Everyone,
I've been busy lately with some family portraits, I've fully embrace this genre full steam and I have been enjoying some of these results. I've wanted to face my fear of off camera flash and decided that this session I was going to out see if I can make it happen.
Please let me know you thoughts on these
All the Best
Alberto
  ILCE-7RM5    Sony FE 85mm f/1.8 lens    85mm    f/1.8    1/2000s    100 ISO    0.0 EV
  ILCE-7RM5    Sony FE 85mm f/1.8 lens    85mm    f/1.8    1/5000s    100 ISO    0.0 EV
May 22, 2023 at 08:12 PM
DanielScott
p.1 #2 · p.1 #2 · Will & Wade
Great use of OCF. It blends perfectly with the available lighting and you made it look very natural, which in my opinion is one way to very successfully implement OCF into an outdoor shoot. I might suggest a larger modifier though, if only to create somewhat larger catch-lights in their eyes.
May 22, 2023 at 10:26 PM
p.1 #3 · p.1 #3 · Will & Wade
These are really nice, Alberto! Great poses for males.
May 23, 2023 at 06:09 AM
Majestictone
p.1 #4 · p.1 #4 · Will & Wade
Thank You Daniel
I’ve been looking into a larger modifier, maybe a 36” beauty dish or larger. Using a Godox AD200Pro, not sure larger would facilitate the power output though unless add another and go dual. What are you thoughts?
Alberto
May 23, 2023 at 06:25 AM
Majestictone
p.1 #5 · p.1 #5 · Will & Wade
Thank You Douglas
story_teller
p.1 #6 · p.1 #6 · Will & Wade
Majestictone wrote:
Thank You Daniel
Alberto
You might try an inexpensive umbrella first to get an idea of the power loss from a single flash.
May 23, 2023 at 06:54 AM
KE_Photo
p.1 #7 · p.1 #7 · Will & Wade
Majestictone wrote:
Thank You Daniel
Well done images!
I use 2-3 single AD200s on location quite a bit for fill (similar to your use here) - even for groups they have plenty of output (I use the Bulb head only - the fresnel head is useless to me)... used in S type brackets with modifiers.
Westcott Halo Mono "brolly boxes" are my favorite for portability, simplicity and light weight. (shooting without an assistant and carrying everything all at once myself on wandering remote shoots that move around) I'm fortunate to have a vintage version that's small (32") and it's the most wind resistant thing I own next to a metal beauty dish. I also have the larger one they currently sell. Beauty dish light can be nice for some things but it's also potentially too hard - good for some looks though depending on your goals.
Foldable soft boxes are another approach - Bowens mount octas in S-type brackets work well with the AD200s. Lots of other alternatives and options out there!
May 23, 2023 at 05:22 PM
Majestictone
p.1 #8 · p.1 #8 · Will & Wade
Thank You
I’ve been doing some research on that halo mono, 45” is the only size I can find. Searched for the smaller size you had mentioned but with no success. Do you feel the AD200 with the bulb will render enough light ?
Alberto
KE_Photo wrote:
Well done images!
May 26, 2023 at 11:52 AM
KE_Photo
p.1 #9 · p.1 #9 · Will & Wade
You're welcome!
I did mention the small one was "vintage" - in other words - discontinued. The Halo Mono is more efficient than a simple shoot through - though similarly, it is an omni pattern. There is no internal diffuser (like a soft box) - the AD200 bulb reflects in the silver internal backing to fill it with light to the edges.
The bulb/AD200 w/this is plenty powerful enough for fill and can cover small groups IMO. (I usually use 2 AD200s for group fill - sometimes one more for backlighting). ***Totally YMMV*** - my needs/style is not highly dependent on HSS/overpowering the sun/darkening the backgrounds - I don't often use the "flash look" very often either. If I don't push the flashes hard they can last a very long time on a single charge.
Majestictone wrote:
Thank You
May 27, 2023 at 09:09 AM
