Alan321 Offline Upload & Sell: Off
traingoof, if you upgrade the computer and also upgrade LrC to a recent version, then you might find that 32GB will be more limiting than it used to be five years ago. At the very least, make sure you can add more later on without trashing what you are about to buy.
If you stick with LrC v 6 then its single-core processing will be the weakest link in any new computer you might buy, because you'll miss out on multi-threaded preview building and GPU processing. I might be exaggerating but I would expect Lr 6 to undermine much of the benefit of a new PC.
Then again, an upgrade from Lr 6 to LrC 12 will cause a shock to your system because the basic editing features work differently and there are many new features to learn and benefit from. You'll need a strategy to manage the change because you won't want to ruin old edits before you understand the new edits. Even so, within a few months you'll probably have updated all of your image edits. I recommend that you not let the new LrC or old Lr write anything to old raw files or sidecar files. Instead, manage your edits in the LrC database and keep it backed up automatically after every session.
