Ross Martin Offline Upload & Sell: On
Eric214 wrote:
Incorrect. The length doesn't change. 18mm is still 18mm. BUT the FOV DOES change on a crop body or APS-C sensor to 27mm FOV equivalent to a 35mm (FX) sensor. You can not make an 18mm lens show 18mm FOV on an APS-C sensor
You are misunderstanding what the OP is asking. He clarified here, read it carefully:
“What I meant was, if you put a 50mm FX lens on a DX camera, will it have a different field of view than a DX 50mm lens mounted on the same DX camera?”
