rscheffler Online Upload & Sell: Off
p.1 #12 · p.1 #12 · Voigtlander Nokton 50mm f/1.0 announced for Canon RF mount | |
For those unfamiliar with Voigtlander and curious about how this lens performs, it was originally released for Leica M mount a little over a year ago and was reviewed by Fred here. The review covers technical aspects such as sharpness at infinity, CA, LoCA, coma, flaring and also character/rendering at various subject distances. There are also comparisons against other fast Leica M mount 50s and the Sony 50/1.2 for mirrorless (possibly one of the technically best 50s currently available, similar to the Canon RF 50/1.2L).
Below is the introduction Fred posted in the review:
The new Voigtlander 50mm f/1 Nokton is Cosina's fastest full frame lens to date and it is capable of very high contrast and resolution. That's quite an accomplishment considering it's a relatively compact 50mm f/1 lens. Cosina attributes this feat to the use of a double-sided aspherical element and a newly developed grinding aspherical (GA) front element.
It's a modern, well-corrected optical design with a promise of delivering high performance even wide open. Thanks to its floating element system, there is very low spherical aberration in the images it produces at close distance.
If Cosina's goal was to design the sharpest 50mm f/1 lens while keeping it as compact as possible, from what I've seen so far, it looks like they achieved this. However, there are compromises to every optical design. Due to the compact lens size and super fast aperture, field curvature and pronounced optical vignetting may cause unevenness in the rendering depending on subject distance.
And Fred's concluding remarks:
After shooting with the Voigtlander 50mm f/1 Nokton for about a week, I came to the conclusion that it’s one of the sharpest 50mm F/1 lenses ever produced. I put this lens through some demanding technical tests, and it's clear to me that Cosina prioritized resolution, contrast and size for this optical design.
Let's start with resolution: Many have been asking for an affordable and fast 50mm lens with a floating mechanism, capable of achieving high close up performance and the Voigtlander 50/1 Nokton delivered. As demonstrated in the side by side comparisons, it clearly outperforms the mighty Leica 50/0.95 Noctilux at close and long distance by a good margin, especially when positioning the subject away from the center area.
In regards to compactness: It's small and light for a 50mm F/1 lens measuring only 55mm in length and weighing 482 grams. Most importantly, it's not front heavy and balances well on the Leica M body, although it still blocks about 20% of the rangefinder's frameline.
But, every optical design has compromises and the Voigtlander 50/1 Nokton is no exception. It has pronounced outwards field curvature and high optical vignetting which is a combination that could cause unevenness in the background rendering depending on subject distance . Although all F/1 lenses tested here have similar character, it's something to keep in mind when composing your scenes with this lens.
The Voigtlander 50/1 Nokton is well corrected for distortion showing only minor pincushion. It also demonstrated great flare resistance when compared to other f/1 lenses, although, there is still noticeable ring flare whenever not blocking side lighting with the hood or your hand.
Ironically, although not a f/1 lens, the Voigtlander 50mm f/1.2 Nokton compared favorably against the Voigtlander 50mm f/1, sharing many of the same qualities while being smaller/lighter and producing a more pleasant and even rendering. This is due to less pronounced field curvature and lower optical vignetting. However, it is ~1/2 stop slower and not equipped with a floating mechanism which means lower performance at minimal focus distance. I consider it a great alternative for those who prioritize rendering and don't mind spherical aberration when shooting wide open at close distance.
Pros:
High resolution and contrast from wide open. It performed better than I expected for a F/1 lens.
Clean specular highlights inner structure thanks to the grinding aspherical process.
Better than average close up performance: The floating design delivers great resolution from MFD to infinity.
Compact (short) and light for a 50mm f/1 lens (482g, measured).
Great build quality with tight tolerance construction.
Well corrected for distortion (negligible pincushion).
Aperture mechanism with 12 straight blades provide defined 12-pointed sunstars.
Great lateral CA correction.
Cons:
High optical vignetting renders 'cats eye' bokeh balls towards the corners.
Pronounced outwards field curvature may cause unevenness in the rendering when shooting wide open.
Noticeable purple fringing and axial CA in areas of high contrast when shooting wide open.
One of the most expensive Cosina lenses at $1,800 (Although way less than the 13K Leica).
Please note that with the RF version Cosina may have slightly tweaked aspects of the lens, whether optically or otherwise, that might affect certain performance aspects. I would expect the RF version is very close in this respect to the recently released version for Nikon mirrorless, but have not yet seen (or looked for) any comparison reviews against the M-mount version.
