StudioAbe Offline Upload & Sell: On
p.1 #1 · p.1 #1 · Spectraview II (NEC) and ColorNavigator (Eizo) Issues | |
Q: How do you run both Spectraview II and ColorNavigator without each interfering with other? After setting up Eizo ColorEdge monitor and installing ColorNavigator, I can no longer successfully launch Spectraview II to calibrate my existing NEC PA monitor.
Background:
I have a 2-monitor setup, and up until now, they were both NEC. NEC's Spectraview calibration software with i1 Display Pro calibrator has done a spot on job of keeping both monitors calibrated.
With the recent update to Spectraview II, the older, secondary monitor is no longer supported by the software, and since it was about time to replace (after 14 years of service), I started looking for its replacement. I've found out that NEC is pulling out of wide gamut monitor market and focusing more on commercial displays. So I went with Eizo's CS monitor (entry level, after all, this was to be used as a secondary monitor).
I set up the Eizo monitor and installed their ColorNavigator software, I calibrated the Eizo monitor using the i1 Display Pro calibrator. All went well there. When I connected the calibrator to NEC monitor and launched Spectraview II to calibrate the NEC monitor, it no longer would recognize the monitor - in fact, it recognizes the Eizo monitor and stalls.
How do I make the calibration softwares to work with their respective monitors without interfering with each other?
