Archive 2023 · af point size adjustment setting question
jaehoppa
p.1 #1 · p.1 #1 · af point size adjustment setting question
so just got an X-T5 and with my X-T4 I was able to adjust the size of the af point after clicking the joy stick but I can't figure out a setting on the X-T5 to enable that. All I can do is just move the point over 1 spot and then change the point size.
Can anyone tell me the setting to enable this?
TIA
Jan 23, 2023 at 07:37 AM
maly149
p.1 #2 · p.1 #2 · af point size adjustment setting question
It should work if you use the back wheel when clicking in the joystick - at least that's how mine worked out of the box.
Jan 23, 2023 at 12:13 PM
anthonysemone
p.1 #3 · p.1 #3 · af point size adjustment setting question
Jae, as maly149 says, works for me in just that way for me on my H2
Edited on Jan 23, 2023 at 04:30 PM · View previous versions
Jan 23, 2023 at 04:29 PM
jaehoppa
p.1 #4 · p.1 #4 · af point size adjustment setting question
Nothing happens when I press in the joystick. Not sure if there is a setting to enable this.
wsheldon
p.1 #5 · p.1 #5 · af point size adjustment setting question
Yes. Check the options under Wrench > BUTTON/DIAL SETTING > FOCUS LEVER SETTING (which is Fuji's name for the joystick)
There are more options than in prior Fuji bodies, and you can assign different functions to PUSH and TILT actions independently. I have PUSH set to EDIT FOCUS AREA and TILT set to DIRECT AF POINT SELECTION, which gives me the most similar (but not exactly same) behavior as my X-T3. With these settings you can move the AF point around without pressing it, and after pressing you can control the size with the rear command dial.
I'd *like* to be able to re-center the AF point simply by pressing the joystick like in the X-T3, but in the X-T5 if you set PUSH to CENTER you then can't change the AF box size with the rear control dial after pressing the joystick any more. So now I have to remember push the joystick then press DISP/BACK to re-center, which is awkward. I guess they're trying to avoid accidentally re-centering the AF when you just want to resize the box wherever you have it positioned.
Restoring the prior joystick behavior is high on many people's firmware wish list, including mine.
Jan 24, 2023 at 08:47 AM
lmhouseman
p.1 #6 · p.1 #6 · af point size adjustment setting question
I do not like the way the X-T5 works. The X-T3 behavior was easier for me. Maybe I've got something set incorrectly, but with the X-T5, I have to move the focus point before I can adjust the size.
Jan 24, 2023 at 07:48 PM
lmhouseman
p.1 #7 · p.1 #7 · af point size adjustment setting question
Ah, I figured it out now. I changed the focus lever setting - push - edit edit focus area. Then use the disp back button to return to center. It works well.
Jan 24, 2023 at 08:20 PM
