Archive 2022 · Denoise AI system requirements
bvphotos
p.1 #1 · Denoise AI system requirements
I downloaded the trial version of this software to use with LR Classic on my Windows 11 desktop with 16GB memory and 6-core CPU. But I've been unable to launch it from LR. According to Task Manager Denoise becomes unresponsive.
I am able to launch Denoise as a stand-alone app, but it's slow and my understanding is that exporting from it results in the loss of a lot of critical meta-data. I like it's noise reducing capabilities (much better than LR), but it's turning to be a PITA to use. Is there a trick to making it behave properly?
Dec 18, 2022 at 11:16 PM
dclark
p.1 #2 · Denoise AI system requirements
I use Topaz Denoise with LR and PS without any difficulty. It is not in the Plugin extras menu. I access it by selecting a files or files and then right click and use "Edit in". There is some delay while the file(s) are converted as per your file setup (Edit > Preferences > External Editing) and DeNoise is opened. Maybe you need to allow more time?
The Topaz apps make heavy use of the GPU, so having a good GPU makes a lot of difference in how quickly it operates. Regardless, they are compute intensive apps and take some time.
I have never noticed any loss of metadata.
Dave
Dec 19, 2022 at 12:10 AM
bvphotos
p.1 #3 · Denoise AI system requirements
I
I think it might be my graphics card that's the problem. It's an old card with not much memory or capabilities. It's been sufficient to power a couple of monitors & edit photos in LR, but I suppose Denoise needs more power.
My understanding is that if you edit photos in standalone Denoise it doesn't save the meta-data. At least that's what I read somewhere.
Dec 19, 2022 at 12:36 AM
dclark
p.1 #4 · Denoise AI system requirements
The system requirements are not that demanding.
https://support.topazlabs.com/article/18-system-requirements
It should work even if it is a bit slow.
I just did a quick check with standalone and see no lose of metadata. I did not check every field but there is nothing apparent.
Dec 19, 2022 at 01:02 AM
EB-1
p.1 #5 · Denoise AI system requirements
I have no problems running the AI Denoise without a discrete video card in an ultra-light laptop, but it is slower than with a RTX 30 series card of course.
Dec 19, 2022 at 01:05 AM
bvphotos
p.1 #6 · Denoise AI system requirements
Hmmm, then I'm back to square one. I literally wait for over a minute for the Denoise window to render itself when I launch it from LR by selecting a photo and clicking on "Edit In". Then I get tired of it and kill it using the Window's task manager. When I launch the stand-alone app, it's a lot faster. Since @dclark confirms that he doesn't see any loss of meta-data, perhaps that's the workflow I need to use. Open a RAW file in Denoise stand-alone app, make my noise related changes. Save it and then open it in LR for further adjustments.
Dec 19, 2022 at 01:20 AM
Zenon Char
p.1 #7 · Denoise AI system requirements
https://support.topazlabs.com/article/115-system-requirements-for-topaz-photo-ai
Edited on Dec 19, 2022 at 07:25 AM · View previous versions
Dec 19, 2022 at 06:51 AM
Zenon Char
p.1 #8 · Denoise AI system requirements
Also Topaz support is pretty responsive.
jrhoffman75
p.1 #9 · Denoise AI system requirements
Do you have a separate GPU or is in a motherboard version?
Dec 19, 2022 at 08:32 AM
Zenon Char
p.1 #10 · Denoise AI system requirements
Not sure if this will help but processor is set to Auto which is likely the Topaz default.
Dec 19, 2022 at 11:08 AM
bvphotos
p.1 #11 · Denoise AI system requirements
Thanks for that. I checked, and my system meets these requirements.
Separate graphics card, although it has something like 2GB memory.
Sorry, not sure I understand. What should I check for?
Dec 19, 2022 at 11:21 AM
Zenon Char
p.1 #12 · Denoise AI system requirements
My fault. I opened Photo AI by mistake. For Denoise it is under preferences.
Dec 19, 2022 at 11:29 AM
Zenon Char
p.1 #13 · Denoise AI system requirements
By the way every time I take it or LrC (not related to Topaz) out of Auto the performance goes south.
Dec 19, 2022 at 12:59 PM
dclark
p.1 #14 · Denoise AI system requirements
bvphotos wrote:
Hmmm, then I'm back to square one. I literally wait for over a minute for the Denoise window to render itself when I launch it from LR by selecting a photo and clicking on "Edit In". Then I get tired of it and kill it using the Window's task manager. When I launch the stand-alone app, it's a lot faster. Since @dclark@ confirms that he doesn't see any loss of meta-data, perhaps that's the workflow I need to use. Open a RAW file in Denoise stand-alone app, make my noise related changes. Save it and then open it in LR
If you can operate Denoise standalone but it does not start when launched from LR using Edit In, the problem is not the GPU. Something is wrong with the way you have setup Denoise in LR. I suggest you follow the instructions in this link: https://support.topazlabs.com/article/54-how-to-install-your-topaz-labs-program-into-lightroom-classic
Once you verify the setup, test it using a single RAW file (make sure only a single file is selected).
Once you click Edit In and select DeNoise, you should see a Input window to select to edit a copy of the file including LR edits, edit a copy, or to edit the original. Make the selection (I always edit a copy with the LR adjustments) and then click the Edit button. After that you will see a status monitor open just above the left hand panel that shows the status of processing the file to open in DeNoise. On my computer it takes a second or two to complete the processing and open DeNoise.
Starting Denoise is a bit slow but it should not take longer than a minute on even the slowest computer.
Dec 19, 2022 at 10:09 PM
bvphotos
p.1 #15 · Denoise AI system requirements
Sorry for the delay in responding. I tried exactly what you suggested. Still no luck. Tried with Sony ARW and Fuji RAF files. The farthest I get when I invoke Denoise via the "Edit In..." function in LR is get that rotating circle (when the file is being opened and processed). The windows task manager continues to show Denoise as not responding. I wait for 2-3 minutes and kill the app. Works just fine when opening the same file directly in Denoise. What I did observe is that it takes nearly 30-60 seconds to save the file in Denoise after removing the noise. As much as I love the output it produces, it's simply way too slow and inconvenient for me to use. I'll contact Topaz's support. If they're not able to improve the situation, this gets filed under "Worthwhile experiments that failed".
Dec 21, 2022 at 08:31 PM
dclark
p.1 #16 · Denoise AI system requirements
Did you see the selection for "Edit a copy with Lightroom adjustments", etc?
Did you see the status bar in the upper left? If so, does it show any progress?
Dec 21, 2022 at 09:07 PM
Zenon Char
p.1 #17 · Denoise AI system requirements
https://www.fredmiranda.com/forum/topic/1778538/1#16126233
https://www.fredmiranda.com/forum/topic/1778538/2#16126235
Dec 22, 2022 at 10:41 AM
bvphotos
p.1 #18 · Denoise AI system requirements
Okay, I sent a message to Topaz about why Denoise won't work for me. In the meantime, following the Zenon's pointer, I downloaded Photo AI. That works in all 3 modes: as a stand-alone app, invoking it using "Edit In' using a TIFF version, and invoking the app via the File->PlugIn->Process in Topaz Photo AI (which processes the RAW file).
I haven't tried many different kinds of files, but from what I've seen, I really like what Topaz's products can do. Clean, sharp output. My understanding is that Photo AI is a reworking & integration of their individual products, and clearly it's a more efficient/optimized product than the originals. Having said that, it does take time to process both RAW & TIFF files. I think that's because my graphics card is anemic, especially in the memory department (I think mine has 2GB). More than any other resource, it's the graphics card & its memory that will have the biggest impact. Which is not surprising given that mathematical calculations on image files (especially matrix geometry) can be memory intensive. So, off to getting a new card. I'll post an update after I install it.
Thanks much for all your help.
Dec 22, 2022 at 10:43 PM
Zenon Char
p.1 #19 · Denoise AI system requirements
Make sure you have the latest version as it gets better every week. It's 1.1.3 as of today.
Dec 22, 2022 at 11:47 PM
bvphotos
p.1 #20 · Denoise AI system requirements
An update...
I upgraded to a Radeon 66xx series card with 8GB VRAM. Photo AI does NOT use the GPU at all, except for a few momentary spikes to 15-30% utilization, with VRAM usage of less than 900MB for a full size A7RIV RAW file. Tried all the available settings. Made no difference. It does, however, tax the CPU, with a consistent 50-60% utilization of the 6-core Ryzen processor. When it believes the photo needs both NR and sharpening, it can take upwards of 5 minutes when you go from the default zoom size to fitting the entire photo in the screen.
I went back to the stand-alone Denoise AI app. It does use the GPU, consistently using over 40% and spiking all the way up to 100% sometimes and around 4GB of VRAM for the same photo.
So a good graphics card makes a big difference to Denoise, but is useless when it comes to Photo AI. I've sent Topaz Labs a message, but don't expect a response for a while due to the holidays. I really want to like Photo AI -- its output, when it eventually produces it -- is far better than anything LrC can do, but in its current state it's unusable for me.
Dec 24, 2022 at 03:01 PM
