suteetat Offline Upload & Sell: Off
p.1 #16 · p.1 #16 · What makes Voigtländer lenses "special" or a better alternative to S lenses? | |
NissanPatrol wrote:
I am not too sensitive to the lens size as long as it is sharp in the middle.
So what adaptor I need to use the Zeiss Milvus 35/1.4 with my Z9
Thanks
For Zeiss Milvus, if you buy the ZF.2 version, it is an F mount version and you can use it with FTZ adapter and
you will get all the exif data. Zeiss 35/1.4 ZM is M mount so you will need M mount adapter. If you get Megadap or
Techart, they willl turn manual focus lens into AF lens. Not as fast as native lens but good enough for stationary object,
most portrait or even street photography.
Vento wrote:
It really depends on what the lens will primarily be used for.
There is no one size fits all 35mm, ultimately you should looking for a lens whose characteristics match your requirements profil.
Do you want to shoot a lot of portrait stuff, how important is AF, how frequently you want to shoot moving subjects, how important are features like weather sealing for you, how fast the 35mm should be and what main strenghts it should have.
The right lid for every pot, it's the same with lenses.
Without knowing what pot you want, lid recommendations only make very limited sense.
If you are looking for a 35mm lens, mainly for landscape, architecture, city-/nightscape, some street photography, you want superb resolution from wide open across the field, highest level of optical corrections allready wide open @ f/2, enjoy shooting with MF lenses, you won't find any better 35mm Z-mount lens, like the 35mm Apo-Lanthar Z.
I can't comment on the Zeiss Milvus 35/1.4, but for the application scenarios already mentioned above the 35 Apo-Lanthar even outperforms the Zeiss Otus 28mm f1.4.
https://www.cameralabs.com/voigtlander-35mm-f2-apo-lanthar-review/4/
...Show more →
I went through the review briefly but I don't see any comparison to Otus 28/1.4. There is a picture of Voiglander next to Otus 28/1.4 but the actual comparison was done with Zeiss Batis 40/2 . I don't see any actual comparison to Zeiss Otus on either page 2 or 4 of the review. Regardless, its compact size with excellent IQ certainly make it a very good option.
