fadeslayer Offline Upload & Sell: Off
PV Hiker wrote:
11/24/2022
Firmware update Version 1.3
Performance of C-AF when shooting still images has been improved.
This is very important to me if indeed it has been resolved. I guess most users might not ever notice this issue.
We had 6 M1X camera bodies and now 6 OM-1 bodies. What I noticed on all 12 camera bodies is when shooting in CAF mode the focus drifts in and out on stationary subjects, like birds on a stick.
Burst shooting the first few shots are sharp and then the next couple the focus is off and then it locks on and sharp again. We have a custom button to quickly go to "C4" that is set up with S-AF that will get the shots sharp.
Using the M1X bodies I contacted Olympus and explained what was happening that CAF was drifting in and out to maintain focus on a stationary object. CAF is designed to adjust for movement so because the subject is not moving it tries to test the boundaries by moving focus in and out to confirm focus.
I sent in one body as they requested and they sent back another replacement body that also preformed the same way. I'm sure they did not understand what was happening or they knew about it and replaced the body hoping I would move on. We did a work around by using "SAF" as much as possible.
We were disappointed when we received the OM-1 bodies that the issue was not fixed. We will see if this firmware has addressed this issue.
Cheers, Patrick...Show more →
Yes, I confirm that behaviour, VERY ANNOYING, even if OM-1 is less disastrous, it still keeps on doing a couple of things that get me angry
- Bird/animal detect find subject, then AF sticks on grass leaves in front of the subject
- Burst on clean subject (no distractions between me and subject), some pictures in focus, then focus goes a bit back or forth, then focus recovers, and then back/forth again.
I will wait to see if this update fixes at least a good bit this behaviour (I can't update it anyway now).
