Macro World Resource
Photoshop CS6 - Focus stacking not working
ahender
p.1 #1 · p.1 #1 · Photoshop CS6 - Focus stacking not working
Hi. The last time I did a focus stack was about five years ago. It was a an image of lichen from a limb which fell in the yard. It turned out beautifully. Trying this again, and after following the same steps, the stacked image is only showing the first image.
Working with about 20 jpegs. Process:
Files->Scripts->Load in stack->Select files->Click OK->Select all layers->Edit->Auto-align
Where am I going wrong on this?
Thanks.
Nov 13, 2022 at 10:19 AM
Imagemaster
p.1 #2 · p.1 #2 · Photoshop CS6 - Focus stacking not working
Donít remember, try YouTube.
Nov 17, 2022 at 03:45 PM
gchappel
p.1 #3 · p.1 #3 · Photoshop CS6 - Focus stacking not working
All you have done is autoalighn a stack of layers.
In normal mode, you will only see the top layer.
Many ways to proceed from here.
Easiest is just select all layers and use auto blend layers, found under edit.
If that doesnít work, sometimes you need to manually correct some areas.
Good luck
Gary
Nov 25, 2022 at 07:45 AM
Username      Reset password
