Bobarino Offline Upload & Sell: Off
20 degrees is wayyyy too narrow/dangerous. The angle becomes even more extreme when you consider that the load tip-over point is the mid-point between two feet/legs.(the shortest distance from center-of-gravity). With an unbalanced load (long lens), the effective angle-of-support to mid-point between two legs/feet, would probably be under 13 degrees, or,,, 2 "seconds" on a clock face..
Considering an analog clock face,,, each minute (or second) on the clocks' face equals 6 degrees. With the tripods' load torqued over that tip-over point between the two feet, I doubt it would take much of a wind-gust before flirting with a potential Kaaa-Booom!!!
Edited on Nov 05, 2022 at 07:09 PM · View previous versions
