J.D. Offline Upload & Sell: Off
The reasons to buy the 75-300 are price, portability and reach. You actually get quite a lot of lens for your money. The problems I have had with it mainly centre around the focusing. As a result I don’t use it very often. On the other hand, it’s so light and small that it’s a good backstop for travel and much easier to carry around than the alternatives (I’m talking exclusively Olympus here).
This is a lens that would definitely benefit from a focus limiter switch because, in my experience, it hunts like crazy. If you can find a subject with good contrast, it will probably work. But in compromised lighting or low contrast, it struggles. With good subject selection - maybe the result of walking further - it can produce as good as a result as any comparable lens.
AF mode is also important when using this lens. Careful selection of the focusing area can make or break the shot with this one. I have never found the IBIS in the E-M1 to be not up to the task so an in-built stabiliser isn’t necessary. For the reasons I have already made clear, you are unlikely to be using it in low light when 7 stops of stabilisation is needed anyway.
I recently returned from a trip with an E-M1, a 12mm f/2, 14-42 f/3.5-5.6, 40-150 f/4-5.6 and 75-300 f/4.8-6.7 and there was nothing I couldn’t do with that selection (though I needed a polariser…). I also had a small Joby Gorilla Pod in the bag for anything that required low shuttler speeds. This whole rig fitted perfectly into a small LowePro Stealth Reporter 300 bag and I hiked with it with no problems.
