Archive 2022 · Sony A1 - Memory Card Door replacement
wayanbarre
p.1 #1 · p.1 #1 · Sony A1 - Memory Card Door replacement
Hi,
I bought a spare part (memory card door/cover - MEDIA LID ASSY (850)) from Encompass to replace mine (was a bit damaged) on my Sony A1 (ILCE-1).
I managed to take the damaged one out of the camera. But I struggle to put in the new one. There is a shaft that doesn't want to go in the 2 top & bottom holes an d I don't want to break it.
Called a repair center and they said the cabinet needs to be disassembled in order to replace the part.
Is anyone knowledgable? I don't see any tutorial/guide on internet :/
Some photos:
https://ibb.co/GcBxG1F
https://ibb.co/tPwL0yD
https://ibb.co/yFDCgD8
https://ibb.co/fQ9qbsk
Thanks!
Wayan
Sep 26, 2022 at 01:16 PM
LiveShots
p.1 #2 · p.1 #2 · Sony A1 - Memory Card Door replacement
The lower part of the rod appears to extend furtherÖ
Did you try inserting the lower end first and then with a flat blade screwdriver push the top end of the rod and angle it into the hole. If that does not work then try the reverse, putting the top rod into the hole first and then lever the lower part of the rod using the screwdriver.
Sep 26, 2022 at 04:20 PM
wayanbarre
p.1 #3 · p.1 #3 · Sony A1 - Memory Card Door replacement
That is exactly what I was thinking about. The rod is quite flexible so that makes sense. However i didnít manage to bend the rod sufficiently to insert the bottom. Same with the top. But thatís how I did to take it off the first time. So I guess I miss THE tool to do it easily!
Sep 26, 2022 at 04:52 PM
LiveShots
p.1 #4 · p.1 #4 · Sony A1 - Memory Card Door replacement
I wonder if you can lever out the box shaped part of the spring from the indent and that would allow the rod to slide up and down. And then lock it back in place when done.
https://liveshots.net/downloads/forums/IMG-3118.jpg
Sep 26, 2022 at 09:13 PM
wayanbarre
p.1 #5 · p.1 #5 · Sony A1 - Memory Card Door replacement
I can slide the rod without any problem. The issue is putting back the rod onto the cameraís holes. The rod is like 1mm longer so I guess I have to put one side on one hole and then bent it to reduce the size and put the other side on the other hole? But even by forcing a little, I struggle. Maybe I donít have the right tools
Sep 27, 2022 at 06:58 AM
LiveShots
p.1 #6 · p.1 #6 · Sony A1 - Memory Card Door replacement
Are you trying the top hole first or the bottom one? I would think it needs to go Top first
Sep 27, 2022 at 07:56 AM
wayanbarre
p.1 #7 · p.1 #7 · Sony A1 - Memory Card Door replacement
I tried both
Sep 27, 2022 at 08:14 AM
wayanbarre
p.1 #8 · p.1 #8 · Sony A1 - Memory Card Door replacement
Finally managed to disassemble the camera. Indeed, there is a full hole at the top. The rod need to go through this hole from the top! https://ibb.co/xqFzXSj
Sep 27, 2022 at 09:13 AM
swldstn
p.1 #9 · p.1 #9 · Sony A1 - Memory Card Door replacement
Keep up and continue to debug. I need to understand this so when my replacement arrives I can understand what to do. Thank you in advance.
Sep 27, 2022 at 02:36 PM
wayanbarre
p.1 #10 · p.1 #10 · Sony A1 - Memory Card Door replacement
I followed this article to disassemble the camera back: Kolarvision
And a photo of the "hole" here
Sep 27, 2022 at 02:39 PM
