Archive 2022 · Can you folk recommend a better tool than Helicon-focus when.....
agrumpyoldsod
p.1 #1 · p.1 #1 · Can you folk recommend a better tool than Helicon-focus when.....
Can you folk recommend a better tool than Helicon-focus when the lens you are using has significant focus breathing across the nearest to furthest focus point in a stack.
I tried using layers in PS and it did not work either.
The following was a render of a 40 shot stack of a subject at 433mm shot with an X2D-100C and 120/3.5 Macro lens, shot tethered and all focus shifts performed remotely (so there should not have been any movement) and I wasted far to long trying to fix the issues. I will shoot again from further away to see if I can reduce the issue.
All raw images are imported in to phocus where precisely the same adjustments/settings and lens correction algorithm is applied to all images.
F/9.0 1/160th ISO 64 -- lit by strobe
  Hasselblad X2D 100C    XCD 120 lens    120mm    f/9.0    1/160s    64 ISO
f/8.0 1/160th ISO 64
  Hasselblad X2D 100C    XCD 120 lens    120mm    f/8.0    1/160s    64 ISO
Sep 25, 2022 at 05:46 PM
Peter Figen
p.1 #2 · p.1 #2 · Can you folk recommend a better tool than Helicon-focus when.....
Did you go into Helicon preferences and up the percentage of resizing that Helicon will do to match images? I think the default is something like 5 percent and the max is 30 percent. If that doesn't help then you can try Zerene Stacker. I use both and, generally, when one has issues the other is better but there is always some manual clean up no matter what.
Sep 25, 2022 at 07:38 PM
agrumpyoldsod
p.1 #3 · p.1 #3 · Can you folk recommend a better tool than Helicon-focus when.....
Hi -- nope and will do. I just reshot the set and these seems to work ok.
Clearly the settings in preferences make the difference. See below.
2% on lateral and rotation and 0% on resize
5% on lateral and rotation and 0% on resize
5% on lateral and rotation and 5% on resize - the clean image.
Sep 26, 2022 at 07:31 AM
agrumpyoldsod
p.1 #4 · p.1 #4 · Can you folk recommend a better tool than Helicon-focus when.....
QUESTION ANSWERED - I will not follow from here
Sep 26, 2022 at 07:32 AM
Peter Figen
p.1 #5 · p.1 #5 · Can you folk recommend a better tool than Helicon-focus when.....
The question was only partially answered so I hope you're still tuning in. There is one more crucial setting in the Helicon preferences - the setting for the type of interpolation used, and since I was not at a computer that had Helicon on it last night, I couldn't double-check that until this morning. You want to set that setting to Lanczos 8, the slowest and best interpolation algorithm choice in that drop down menu. That will also make a huge difference in some types of artifacting but will slow down the process, but who really cares if the results are better.
Sep 26, 2022 at 12:50 PM
agrumpyoldsod
p.1 #6 · p.1 #6 · Can you folk recommend a better tool than Helicon-focus when.....
Yes still listening and I had selected L8 — using a Mac studio ultra nothing takes long.
The initial output from my tethered stacking can be seen HERE
Thanks
Sep 26, 2022 at 01:52 PM
