jlafferty Offline Upload & Sell: Off
p.1 #4 · p.1 #4 · Portable strobe options with good color consistency | |
I’ve tested the 600Pros with the C700 color meter and they don’t test as well as the specs, but they’re close, and they test far better than a lot of pro strobes out there (e.g. the Profoto B1). I didn’t test them in HSS for color (not sure you can test both HSS and color with one meter), but Rob Hall did a video early in the 600Pro/400Pro release where he demonstrated that they shift along the green/magenta axis in HSS, but again not nearly as much as the B1/B1X.
FWIW the color delta on the 600Pro across their power spectrum was, in my testing, +/- 90K in color stable mode. But for general use, even in regular “non color” mode, the shift is so little as to not be a serious issue. Given this, I trust the 400Pro and 300Pro behave similarly. I don’t have a 400 but regularly mix the 300 in with my 600s and it seems great.
As an aside, you’ll find an added complication is that your modifiers will add their own color cast - my Photek is a little green; a Photoflex umbrella and one of my silver reflectors are very green.
