Raw processing
NissanPatrol
p.1 #1 · p.1 #1 · Raw processing
The original is faint because of fog
Dxo is the best but nx studio is not bad at all
Also DxO is minimum effort because I did not touch any slider (only selected deepPrime)
Original
NX - Studio
DxO photo lab 5
Aug 05, 2022 at 03:37 AM
sjms
p.1 #2 · p.1 #2 · Raw processing
I use DXO’s NR capabilities in various ISO ranges for noise reduction. I rarely use deep prime. As fog and haze are environmental effects that I wish to reduce/control I prefer using the Clear View plus feature and slider in what I prefer.
Aug 05, 2022 at 03:55 AM
NissanPatrol
p.1 #3 · p.1 #3 · Raw processing
if you are not using deepPRIME so what DxO settings you use for denoising, prime or high quality?
Aug 05, 2022 at 04:46 AM
Paul_K
p.1 #4 · p.1 #4 · Raw processing
Not an expert on post procesing, only have Nikon NX D, last time I use Photoshop - version 3.0 to be exact - was in 1995, also don't have / use DxO
So it's not exactly clear to me what you want to show with the images processed with different programs, as in my humble opinion they all look pretty much non processed
Although I don't have acces to the original RAW file, and instead just used the JPG file posted, I'm able to get a IMO much better result using Nikon Capture NX D doing, again IMO, despite the fog and not suing any kind of noise reduction, more justice to the image taken
Aug 05, 2022 at 05:38 AM
sjms
p.1 #5 · p.1 #5 · Raw processing
i use any of the 3 levels appropriately. HQ when only a light level of denoising is needed. Prime when it requires a bit more finesse. and DeepPRIME when it more needs aggressive cleaning. there is no one method that does it w/o having other effects. you need to balance your visual output. and its done in raw
Edited on Aug 05, 2022 at 06:50 AM · View previous versions
Aug 05, 2022 at 05:56 AM
sjms
p.1 #6 · p.1 #6 · Raw processing
it is a very small jpg to start with so there's little to work with
wish i had the raw to work with
Aug 05, 2022 at 05:58 AM
RoamingScott
p.1 #7 · p.1 #7 · Raw processing
Sometimes an image can't be saved and discretion is the better part of valor. This is one of those times.
Aug 05, 2022 at 07:26 AM
sjms
p.1 #8 · p.1 #8 · Raw processing
haven't seen the original raw so i won't say its lost.
Edited on Aug 05, 2022 at 09:16 AM · View previous versions
Aug 05, 2022 at 07:43 AM
NissanPatrol
p.1 #9 · p.1 #9 · Raw processing
Very good outcome
What I am trying to show?
Trying to get feed back if I can optimize my post processing further without looking artificial .
From the replies it is obvious there is room for improvement.
Aug 05, 2022 at 08:16 AM
MRomine
p.1 #10 · p.1 #10 · Raw processing
Paul_K wrote:
...last time I use Photoshop - version 3.0 to be exact - was in 1995
Wow, I too started with that version. That was an entirely different way of editing. That was before layers were introduced in PS so you had to make versions and save them as you made changes. Very archaic compared to today's versions.
Aug 05, 2022 at 08:48 AM
sjms
p.1 #11 · p.1 #11 · Raw processing
i try to make my editing/finishing a simple as i can to get to the point of satisfaction.
i don't use about 80% of PScc today. but what i do use is what i feel i need.
Aug 05, 2022 at 09:11 AM
sjms
p.1 #12 · p.1 #12 · Raw processing
there are subtle differences between the two lower images
Aug 05, 2022 at 09:14 AM
RoamingScott
p.1 #13 · p.1 #13 · Raw processing
2 sliders in LR give a better result than any of those AI tools (and I didn't even have the RAW), proving that knowing how to PP beats relying on AI. Take some time to learn and your photography will benefit greatly.
Aug 05, 2022 at 09:25 AM
sjms
p.1 #14 · p.1 #14 · Raw processing
what AI tools are you referring to?
Aug 05, 2022 at 09:34 AM
CanadaMark
p.1 #15 · p.1 #15 · Raw processing
Programs like DXO Deep Prime provide only a starting point, as that just replaces your basic RAW conversion, and for that purpose it does a way better job than anyone could manage in Photoshop. If you don't do anything with the image after that, then you are still wasting your time. The idea is to use the best possible RAW converter, and then edit the resulting RAW image as normal. The AI tools are not meant to replace most normal processing steps, their value is in the conversion which they do far better than Adobe. If people are just batch processing their RAWs in DXO and leaving them alone after that, they are missing the point. It's not meant to be relied on for anything except the very first step in a normal processing workflow.
OP: If you want to make the RAW available somewhere for download it might be fun to see what we can get out of it.
Aug 05, 2022 at 12:44 PM
bs kite
p.1 #16 · p.1 #16 · Raw processing
Interesting idea to make the RAW available. for download.
Aug 05, 2022 at 01:36 PM
RoamingScott
p.1 #17 · p.1 #17 · Raw processing
Then I must be missing the point of this thread.
Aug 05, 2022 at 02:14 PM
sjms
p.1 #18 · p.1 #18 · Raw processing
i would say there is a chance of that.
Aug 05, 2022 at 02:21 PM
NissanPatrol
p.1 #19 · p.1 #19 · Raw processing
Unfortunately the raw file in a hard disk 1000 km away from where I am.
I will be there next Tuesday I will post it then after I find where to host it.
Aug 05, 2022 at 02:38 PM
sjms
p.1 #20 · p.1 #20 · Raw processing
i can wait
Aug 05, 2022 at 02:40 PM
Username      Reset password
