AcuteShadows Offline Upload & Sell: On
p.1 #7 · p.1 #7 · NIKKOR Z 14-24mm f/2.8 S vs AF-S NIKKOR 14-24mm F2.8G ED? | |
CanadaMark wrote:
How badly do you need F2.8? If you can do without, the Z 14-30/4 is better optically than the F-mount 14-24/2.8, takes screw-on filters, and is extremely compact.
If you need F2.8 and want the best possible quality then the Z 14-24/2.8 is as good as it gets. It's expensive, heavy, and annoying to use filters with but that is the case with pretty much all flagship UWAs.
I went with the 14-30/4 and I love it. It's so compact and easy to pack (way smaller than the 16-35VR it replaces), and you are already ahead of most if not all F mount UWAs in the IQ department. That being said I never require F2.8 on the wide end and almost always am at F8-11, so YMMV....Show more →
The 14-30mm f/4 is also very much worth the money. Some further observations on the 14-24mm f/2.8 S:
1. With a wide angle, you probably rarely need f/2.8. f/1.4 makes a difference, but f/2.8 most often does not. But the f/2.8 maximum aperture reduces vignetting at f/4 and f/5.6.
2. Don't buy the 14-24mm f/2.8 because of the aperture, but because of its optical quality.
3. It's large, but not heavy. In fact, it is surprisingly lightweight.
4. Using filters on the 14-24mm f/2.8 is not annoying, but paying for 112 mm filters may well be.
