vbnut Offline Upload & Sell: Off
I read a bunch articles on the web and watched several YouTube videos about setting up the R3 (especially the AF for wildlife and BIF) before renting an R3 (and R5) for a week a couple months ago. After renting the Sony A1 for a week (to rule it out), a week ago I purchase an R3, and have been revisiting the videos while setting up my copy and experimenting with it. I now have several questions.
- It seems the most frequently recommended approach for back-button AF is to change the shutter button from "Moving AF pt, meter., AF by eye ctrl" to "Metering start" and change a back button to "Metering and AF start" (the AF-ON button does this by default). Can anyone explain why we would want to do metering when we start AF when we're going to get metering anyway when we press the shutter button?
- To get back-button eye-control AF the recommendation is set another button to "Moving AF point, start AF by eye ctrl", but in my experience to get that button to use eye-control you also have to enable eye control (by default using the SET button). When eye control is enabled the eye control pointer is visible in the viewfinder when doing eye control AF (which is desirable), but also when not doing eye control AF (which is distracting and undesirable in my opinion). Is there some way, that I've missed, to enable eye control and do "Moving AF point, start AF by eye ctrl" with a single button press?
- In my experiments, is appears that invoking "Moving AF point, start AF by eye ctrl" uses the current AF settings (AF operation, AF area, Subject tracking, Subject to detect, Eye detection, etc.), whether eye control is enable or disabled. I think that means that when eye detect is disabled, "Moving AF point, start AF by eye ctrl" is equivalent to "Metering and AF start" with the default details which mean is uses the current AF settings (except for the metering which seems unnecessary to me). Does that make sense or am I missing something?
If my understand is correct I think it makes sense for me to use "Moving AF point, start AF by eye ctrl" as my primary AF back button, whether eye control is enabled or disabled. That will allow changes I make to AF settings (e.g. AF area) to take effect in both eye control AF and non-eye control AF. I then only need to use "Metering and AF start"on other buttons for cases where I want to start AF with specific AF settings (details specified by pressing the INFO button).
