EB-1 Offline Upload & Sell: Off
p.1 #12 · p.1 #12 · The most efficient way to transfer pictures from the camera? | |
Kalainen wrote:
Hi everyone,
I'm in the process on building a new editing pc for my photography work. The pc itself is getting together nicely, but I would also love to change the way how I transfer the pics from my camera to my computer.
Here's how I do it now and what's the problem:
- I have a Sony A7III and attach the cable from camera to front usb panel of my aged computer. I believe the usb is 2.0 (it's over 10 years old computer) and I'm using Sandisk Extreme Pro SDXC I (95 MB/s) cards in my camera. It takes quite a long time for 64 Gb transfer and since I'm building a new computer I might as well change this as well.
Now the new computer will have usb 3.0 and usb c-type 3.0 in the front panel. If I just attach the same cable as before, should I experience faster transfer times? I do understand that this is a pretty newbie question, but I've been away from computer tech for some time crafting images.
Or should I invest into somekind of card reader? Maybe I should also get new cards for my camera?
I'm sure someone here knows the answers..
...Show more →
EB-1 wrote:
A current motherboard should have a USB 3.1/3.2 Gen 2 (10Gbps) header that you can can attach to a USB-C port on the case. The typical USB A case ports attach to a USB 3.x 2-channel header that may only run at 5Gbps (USB 3.0/3.1 Gen 1/3.2 Gen 1). Check your online manual to ensure that the USB port used is at the full speed of the reader for maximum performance. Of course a Gen 2 reader can operate at half speed just fine on a USB 3.0/3.1 Gen 1/3.2 Gen 1 port.
Kalainen wrote:
Call me simple, but I need some more explaining.
The motherboard will have USB-C header (even with 60w quick charge support). The case has USB-C port on top of it. So, I'll attach these two together to have maximum speed. But do I connect a card reader into that port or just my Sony A7III camera directly? And if it's a card reader, I should invest into one that reads the cards that I'm using with my Sony, so that's SDXC I and maybe the SDXC II for the future? These must be pretty simple question, and they surely make me look lke a pretty simple person, but somehow I've managed to use Sony A7III for years without really thinking how the cable transfer from the camera actually works. I presume it is USB 3.0, 3.1 Gen 1 or 3.2 Gen 1? Or is it just USB2.
...Show more →
It is nice to have the fastest 3.x port available for the future when you may be using CFe or SDe cards that can take advantage. However, SDxC only needs USB 3.0 as the UHS-II transfer rates are limited to about 300MB/sec. If nothing else is decided, just buy a card reader and don't use the camera. You don't need USB-C for SDxC although there are some. I use the Sony MRW-S1 for SDxC cards and don't waste my USB-C Gen 2 ports on it because UHS-II is the bottleneck.
