highdesertmesa Offline Upload & Sell: On
p.1 #7 · p.1 #7 · Leica 50mm f/1.4 Summilux 'black chrome' hood issue | |
Fred Miranda wrote:
Thanks for your comments guys.
Yes, I was under the impression that when engaging the hood tabs, the internal grips would clamp in 2 sections. One on the lens indentation and the other right on top of the lens. If a filter shares the same lens diameter, the hood upper grip would not be able to clamp on. If we can find a filter that's slightly smaller in diameter, it may work.
I forgot where I read this but I believe that if one attaches the original hood filter and drops a regular 43mm filter from the top, both hood grips can be engaged and the filter can rotated into the lens thread. Perhaps that could be solution as well. I should have my copy arriving in a couple days but may not even use the hood on it....Show more →
The only filters found by people posing in the super-long Leica Forum thread about the issue that would work was one no-name Chinese brand filter, something I definitely would not put in front of glass like the 50 Lux. No major brand with decent glass in the filter would work. There were a lot of filters tried.
The method of dropping in the filter on top of the hood and screwing them in together does work. It pinches the bottom tabs between the bottom of the filter ring and the lens when tightened. The filter can never be fully screwed down since the tabs are there in between now, so you have to be ok with that. This method would be more of a solution for putting on a protective filter and leaving the whole contraption assembled as-is. But it makes taking the filter on/off for a polarizer or color filters for monochrome a pain. Also when screwed in like that, it's nearly impossible to screw to get the nice white text on the hood ring aligned perfectly in the center, which my OCD could not abide
Fred Miranda wrote:
I like the classic design and already know how it performs owning the black anodized version for a couple years. I will own both version for a while and decide which one I like the most.
The feel of the BC is in a league of its own – super dense all brass with the nice texture of black chrome. This is probably the last black chrome lens Leica will ever sell new since they are moving to the black textured paint like the M11 and limited edition 28 Cron that just came out. Something about the black chroming process was not environmentally conscious enough for Leica. The BC focusing ring is incredible, and the aperture ring was really great, too. I find this design much easier to focus than tabbed lenses like my 28 Lux, but to each their own with that.
The biggest drawback of the BC is its biggest positive, IMO – the dense weight. Because of that, it was a lens I used either alone or with one other lens in the bag. But hey, you could use this as an excuse to get the black M11 so you can offset the added weight of the BC
