Nice! New Panasonic lens
johnvanr
p.1 #1 · p.1 #1 · Nice! New Panasonic lens
https://www.bhphotovideo.com/c/product/1705523-REG/panasonic_h_x09_leica_dg_summilux_9mm.html
May 17, 2022 at 09:42 AM
Robin Smith
p.1 #2 · p.1 #2 · Nice! New Panasonic lens
Just what I'm looking for! Looks great. Didn't need to be f1.7, but looks good.
May 17, 2022 at 10:56 AM
Michael Gordon
p.1 #3 · p.1 #3 · Nice! New Panasonic lens
Not many choices for ultrawide primes. Corners look a tad soft even stopped down a bit. I wonder how it will perform for astro? The small size is nice but probably couldn't prioritize minimizing vignetting. I also wonder about coma performance. Suspect it might be better in the end than defishing the Oly 8/1.8 fisheye pro. Time will tell.
May 17, 2022 at 05:55 PM
doady
p.1 #4 · p.1 #4 · Nice! New Panasonic lens
I was hoping for a bright and weathersealed Pro ultra wide prime from Olympus/OM as my second lens to complement 12-100mm F4, but I settled for 8-25mm F4 when it was announced, also weathersealed and taking 72mm filters. 9mm F1.7 will still fill a big gap in the system, but my priority now is probably 100mm macro.
May 17, 2022 at 06:26 PM
johnvanr
p.1 #5 · p.1 #5 · Nice! New Panasonic lens
Me too. Wish it was a 21mm-equivalent, but probably get it anyway.
May 17, 2022 at 07:04 PM
Robin Smith
p.1 #6 · p.1 #6 · Nice! New Panasonic lens
You can always try the Laowa 10mm, about the same price.
May 18, 2022 at 09:16 AM
Michael Gordon
p.1 #7 · p.1 #7 · Nice! New Panasonic lens
Starry sky AF is the cat's meow so prefer AF for astro landscapes if possible. Finally found a review that looked at comatic aberration and not so great at F1.7 as expected.
It appears likely that he used a converter that probably used the baked in linear distortion correction so might not be as bad if use another converter that can ignore that metadata--- (depends on the algorithm used in the correction. ) I don't hold out much hope that the coma performance is actually acceptable at F1.7 though. It is a fine interesting lens and great for many applications but may not be optimal for astro. Perhaps Oly (OM systems ) will make a rectilinear fast WA with different design
choices so is better for astro. At least one can hope.
May 19, 2022 at 05:30 PM
Robin Smith
p.1 #8 · p.1 #8 · Nice! New Panasonic lens
Does the Laowa have a hard stop infinity? Are really expecting perfection across the frame at f1.7 in a 9mm? Seems a tall order in a $500 lens. Not even sure it is possible.
May 20, 2022 at 10:07 AM
johnvanr
p.1 #9 · p.1 #9 · Nice! New Panasonic lens
For a little bit more, I take the AF and weather sealing and forego my exact preferred focal length.
May 20, 2022 at 01:53 PM
Username      Reset password
