gdanmitchell Offline Upload & Sell: Off
Peter Figen wrote:
While I don't shoot sports, I do shoot a ton of live music in dive clubs and not so dive clubs. That's very akin to shooting sports but usually in much worse conditions, lighting wise. I would think that the 135 would be a good lens for the times that it's the right focal length for you shot but so often it's not. My favorite all time lens for ths would be the 70-200 2.8 v2 or 3 (with the 1.4 converter too) and reserve the 135 for those few occasions where you absolutely need the extra stop. You will severely limit your framing capability by using the prime all the time. ...Show more →
That's pretty much my take on this, too.
I used to use the wonderful EF 135mm f/2L lens, and one of the main reasons I had it was for indoor event photography, most of musicians but also some theatrical performances. When (and if) I put myself in just the right spot, it worked beautifully for those subjects...
... but, as you note, "often it's not" quite right. Either you need a bit larger angle of view to include more or you want to get in close for a tighter shot of one person. With the prime — and they have advantages for some things — you aren't going to be able to respond to these things as quickly, if at all.
The 70-200mm f/2.8 is a real workhorse for this kind of stuff. With modern sensors, you can shoot in pretty low light at f/2.8, and the IS feature extends that range further in some situations. And, obviously, you can respond to those changing circumstances.
Back to our OP, I have questions about what he is describing. He asks about shooting "sports," but then mentions that his "toddler" is about at that age. It seems safe to assume that a current toddler isn't likely to be playing NBA basketball or competing in giant slalom any time soon, so I wonder what he is really thinking he'll photograph? Is he thinking forward to T-ball? Swimming lessons? Something else?
Because what makes a fine "sports" lens in the usual context is generally a lot different from what makes for a good lens to photograph the kids.
