freaklikeme Offline Upload & Sell: On
Peter Figen wrote:
Can you actually shoot tiffs in camera on that model? Well, it looks like you can but the question is why would you want to. No matter what format you specify for the camera to write to the card, they all HAVE to start with a RAW file exposure in the camera. The camera then processes that raw file into the requested format. So if you're setting the camera for a tiff file, the camera is doing the conversion from RAW to tiff for you and you have little or no control over that. Specifically, you won't have all the choices you would have when you process the RAW fie yourself in the RAW processor of your choice - White Balance, Color Temperature, Highlight and Shadow recovery, Selective Color, Sharpening, or more importantly, turning that off and even more important, the choice of using a better, more effective RAW processor that Fuji's own, and don't fall into the mistake that so many people make of assuming that the manufacturer's software is the best and only way to convert.
Shoot RAW and process them yourself to your liking, plus the RAW files are a lot smaller than the final tiff is, taking up far less memory on your cards. ...Show more →
It's not so much shooting TIFFs as it is letting the camera process TIFFs out of the captured RAW. I like it because I really like some of the film emulations as jumping-off points for post, particularly Velvia, which reminds of shooting Ektachrome only with more latitude, the Pro Neg options, and the Monochrome option with the red, yellow, and green digital color filters. And your ability to control the final image is surprisingly robust. It's not like having PS or C1 on camera, but it's fine enough to produce a file that won't need much help in post. Even if you're shooting with non-system lenses, you can create up to six profiles for adapted lenses that includes distortion correction, vignetting correction, and color shift correction.
I think the best thing about it is, once I've got the C1-6 slots set up the way I want them, I can create a mostly print-ready file exactly as I saw it through the EVF. I'll still have the RAW if I need it, and will use RAWs for exposure bracketing and panos, but, if I like what I'm seeing in the camera, which I have for the most part, I'll process that and use the TIFF.
