Moss Capsule Stereos: Laowa 25mm x2.5 to x5
e6filmuser
p.1 #1 · p.1 #1 · Moss Capsule Stereos: Laowa 25mm x2.5 to x5
I found these, almost ripe, moss capsules. The lowest magnification of the lens was a bit too high on my m4/3. I had been wanting to use the A7r3 for macro with this lens so I gave it a try.
I used twin flash. They should have been set for TTL but one was on manual hence the low ISO.
These stereos are crosseye, using uncropped images.
A7r3, Laowa f2.8 Ultra Macro 2.5 -5x at 2.5x and f11 ISO 50. Hand held. FOV 14mm wide.
Harold
Harold Gough 2022
Harold Gough 2022
Harold Gough 2022
Harold Gough 2022
Edited on Apr 24, 2022 at 03:43 AM · View previous versions
Apr 23, 2022 at 06:58 AM
smpetty
p.1 #2 · p.1 #2 · Moss Capsule Stereos: Laowa 25mm x2.5 to x5
How much separation between the photos do you use in macro situations? I know that 2.5" or about 6 cm is optimal for most non-macro situations.
Great stuff - I never knew moss capsules were so beautiful!
Apr 23, 2022 at 08:01 AM
e6filmuser
p.1 #3 · p.1 #3 · Moss Capsule Stereos: Laowa 25mm x2.5 to x5
Thanks.
I don't measure. I just estimate the required change of angle of view. As I shoot stereos in every session it becomes almost automatic.
The detail should be much more interesting when they open up but I have no idea when that will be.
Harold
Apr 23, 2022 at 08:28 AM
LordV
p.1 #4 · p.1 #4 · Moss Capsule Stereos: Laowa 25mm x2.5 to x5
Nice stereos Harold.
Brian V.
Apr 23, 2022 at 11:53 PM
e6filmuser
p.1 #5 · p.1 #5 · Moss Capsule Stereos: Laowa 25mm x2.5 to x5
Brian V.
Thanks, Brian.
I was attracted to the group of golden capsules. I took some low magnifications shots with my Olympus, which do not belong in the Sony forum, which was my priority for these.
The low mag ones will be posted soon in my usual forums.
https://www.fredmiranda.com/forum/topic/1753486/0?nc=1#15925389
Harold
Apr 24, 2022 at 01:32 AM
p.1 #6 · p.1 #6 · Moss Capsule Stereos: Laowa 25mm x2.5 to x5
Beautiful.
Apr 24, 2022 at 11:58 AM
Username      Reset password
