rscheffler Offline Upload & Sell: Off
Would be good to see a photo of the set up or some of your results to be sure I’m following along. I’m sure there are a ton of videos available about soft lighting, feathering, etc. but I found this one quite informative for his thoughts about feathering. Just ignore that he’s an Elinchrom ambassador if you have other lighting equipment preferences.
From what you’ve described, it sounds like extreme feathering. Almost to the point that there’s no direct light from the face of the modifier falling on the subject. So then where is the light coming from? Reflecting off the environment around you and lighting the subject? IMO, if seated where the subject will be, I want to see some of the modifier’s face. For corporate type headshots I want to have good light on their eyes without shadows from the side, like that cast by the nose due to cross lighting. Sure, it depends on the person’s face too, and I agree, certain types of lighting flatter some more than others. I’ve generally avoided clamshell lighting from each side for this kind of work, preferring instead a single key light and a reflector for fill. I prefer to see some uniform directionality in the light, rather than it looking like light coming from a couple directions. For softness, I play with distance between the subject and the key light’s modifier and the amount of feather. My usual go-to is a 39” octa.
Most recently for ‘mass’ portrait sessions where I’ve got maybe 5 minutes with each person, I’ve set up two key lights. One in the form of the 39” octa in a classic butterfly lighting position directly on axis with the camera and slightly from above on a boom, with a frosted silver reflector below for fill. Kind of like the horizontal clamshell you mentioned. This is flattering light for many women. The other key light is a ~60” octa to the side with the face turned roughly 90˚ from the subject to feather across their face. When I use this key light I turn off and rotate the boomed octa away so it doesn’t indirectly affect the image. When I use the 39” octa, I turn off the 60”, but don’t rotate it away. The size of the larger modifier as key light with this feathering means that light wraps a fair amount around the far side for a soft falloff. I just keep the silver reflector below for simplicity, but it could be moved to the opposite side if more fill is desired. This way I’m able to quickly pick which of the two looks I think will be most suitable for the person currently sitting in front of me. Of course if there’s a lot more time then I’ll move things around to optimize for the person’s features. But when moving people through every 5 minutes I want to avoid moving lights to keep everything consistent and post production as hassle free as possible.
