rscheffler Offline Upload & Sell: Off
Mine has very slight, almost imperceptible 'lag' when changing focus direction. Is this what you mean? I don't notice it in regular use and otherwise it feels pretty tight. No obvious wobbles, etc. That said, if using it in live view with focus magnification, I can see the image shift slightly when I make a focus adjustment. So something is probably not quite at 'Leica levels' of manufacture, but so far it's been OK.
Recently I noticed a rough spot in the focus throw near MFD, but it could be a small piece of grit in the helicoid.
I did have a problem with mine exhibiting what I thought was excessive field curvature and focus shift. It was sent back to the 'factory' for servicing and took about 5 months. This was through Kevin who acted as middleman for those who bought it through the RFF thread. If you bought it elsewhere and the problem you described is bothering you, an exchange would probably be the better option. Or, if you have a trusted Leica service person, it's probable they could look at it, considering it's 95% a clone of the Cron v1. If you were in the US, one suggestion would probably be DAG. Though there too you'd likely experience some delay.
