Steve Spencer Offline Upload & Sell: On
budjames wrote:
I satisfied a lifelong goal to shoot with Leica with the purchase of my first Leica, the M10, in November 2017. With the camera, I purchased the Summicon 35mm, Summilux 50mm and APO Summicron 75mm lenses.
I immediately had issues trying to get consistently sharp images with the 35 and 50. At first, I thought it was just me having to relearn how to manually focus, the problems persisted. I look the camera and three lenses to the Leica service center in mid-December. The technician checked out my gear and told me that the 35 and 50 were terribly out of calibration. The camera and 75 tested to be within spec. I left the 35 and 50 with them for adjustment. Because of the coming Christmas holiday shut down, I didn't get my new lenses back until mid-January. I spent over $16k for new gear and I couldn't enjoy if over the holiday season.
Since then, I purchased a second M10 body, had my original M10 factory-converted to an M10-P, and purchased the Summilux 35, Super Elmar 18, APO Summicron 50mm, APO Summicron 90mm and APO Summicron 35mm.
The already once repaired Summicron 50mm focusing and aperture rings because loose so I had to send this to Leica to get fixed. The APO Summicron 50 came loose in the same way after about 6 months of casual use and had to be sent into Leica.
Earlier this year, I purchased the M10-R. It's my favorite so far, but I started noticing a lot of hot pixels in underexposed areas with images shot with an ISO greater than 2500. I had the send the camera to Leica and they replaced the sensor and shutter. Fortunately, it only took about a week for them to affect the repairs.
Prior to owning Leica, I shot Canon film and then digital pro SLRs fir 20+ years, then switched to Fuji-X gear for about 4 years before buying my first Leica. With hundreds of thousands of images shot with Canon and Fuji-X, I never had any of that gear fail me or require servicing of any type. I was expecting this from Leica, but that has not been the case.
I love Leica and I sold off my Fuji-X kit 4 years ago to finance the acquisition of Leica lenses, so I'm 100% committed to Leica now. However, the quality control has been very disappointing. This is especially painful since I'm not a professional and my gear is loving cared for. I now only shoot about 24,000 images per year.
If Leica is listening, they should really focus on their quality control.
Regards,
Bud James
Please check out my fine art and travel photography at www.budjames.photography.
...Show more →
Although I certainly sympathize with the problems you have had, I would like to add four thoughts:
1) A rangefinder system is always going to need far greater calibration between lenses and the camera than a DSLR or mirrorless system. Having to calibrate lenses is something you have to put up with from time to time if you want to use a rangefinder. If I counted right you have had 8 lenses and two of them needed calibration with the rangefinder. That is definitely on the high side, but is still a small number of lenses so within what could be expected. I think you are noting that rangefinder cameras have this issue more but I don't think it is a Leica issue but rather a rangefinder issue.
2) The sensor on your M10R needed to be replaced and Leica handled this quickly and solved the problem well. I think how Leica responded here is commendable. All companies have sensors with too many hot pixels from time to time. Your experience suggests that Leica handled this very well. Leica in the early days had more issues with sensors than other cameras (problem with the M9 are a salient example), but that appears to mostly be in the past.,
3) You report loose focus rings on two lenses. I have never had any of these issues, and again even among your lenses it is just two examples. I have not heard this is a particular problem with Leica lenses whereas it was (or rather lens wobble) with Zeiss ZM lenses that were made by Cosina. I think this was likely bad luck and at least the fix is easy.
4) What you don't note is the optical quality of Leica lenses. One thing that I have noticed and Fred has commented on is how wonderfully centered Leica lenses are and this is a frequent problem with other brands. The general lack of centering issues for me makes it easy to put up with the inherent calibration issues of a rangefinder and personally would let me put up with a loose focus ring or two that needed to be sent in to get fixed. I think on the optical side Leica has excellent quality control, on the physical side they are about average (which isn't that bad considering for M lenses anyway the challenges of their small size), and no doubt have way more calibration issues because of the use of the rangefinder. I don't find that to be too bad overall, but YMMV.
