jbledsoe Offline Upload & Sell: Off
My first question would be, what mode are you using? (Test in manual)
Next, did you verify exposure compensation is set to zero?
Next do you have a setting locked?
If not in manual and/or one of these you might see this under the right conditions.
A quick test. Do a configuration backup, factory reset. Verify it took. Do NOT format the card with your backup.
Set to manual mode and zero exposure.
Enable auto iso with default low and high or say 100 and 3200.
Either change subjects or if locked on a tripod, simply change either speed or aperture and see if the iso changes.
If no, likely need to get it fixed.
If yes, your saved configuration has a setting that is causing your issue, import your configuration and find/fix it OR set your preferred settings and verify auto iso still works, if yes, get a configuration backup and save it off card so you can simply restore it in the future as needed.
You stated your photos were out of focus. I'm assuming you mean you had a focus lock but the speed was so low that you ended up with blurry photos due to movement. Remember if you are shooting in aperture mode with auto iso enabled, I believe it will always adjust speed before iso. This is one reason to test your issue in manual mode. Isolate away from the variables ;-)
This might help, it shows rules and behaviors for auto iso on your d850.
https://onlinemanual.nikonimglib.com/d850/en/10_iso_sensitivity_02.html
