NEVER use Paypal Gift, Venmo, Zelle, Apple Pay, Google Pay or any other uninsured payment!
FS: FLM CP26-Travel Carbon Fiber Tripod + FLM CB-38FTR Professional Seri...
mj109
p.1 #1 · p.1 #1 · FS: FLM CP26-Travel Carbon Fiber Tripod + FLM CB-38FTR Professional Series Ball Head
 Item updated in the last 24 hours    FLM CP26-Travel II 10X Carbon Fiber Series II Tripod - excellent for fuji, canon, Sony mirrorless cameras
Available 3 following
Price: $275.00
Shipping instructions: price is to your door
I am selling my lightly used FLM CP26 travel tripod. It is in excellent condition and is in perfect working order. A really nice solid travel tripod. I used it with my fuji xt-3 with a heavy 100-400mm lens with no issues.
Comes with original box, and a nice case (new).
Manufactures description:
Key Features
Load Capacity: 26.4 lb
Maximum Height: 54"
Minimum Height: 2.1"
Folded Length: 17"
Leg Sections: 5
Weight: 2.47 lb
10x Carbon Fiber Legs with Twist Locks
1/4"-20 Threaded Accessory Mounts
The CP26-Travel II 10X Carbon Fiber Series II Tripod from FLM is a 5-section support with a twist leg lock system. A simple turn disengages the leg locks, which extends the legs for the tripod to reach a maximum height of 54". This lightweight travel tripod has a load capacity of 26.4 lb, and is suitable for use with DSLRs, Mirrorless cameras, compact cameras, and more.
For low perspective shooting, the legs may be opened in multiple preset angles, allowing a minimum height of 2.1". Independent leg spread permits the CP26-Travel II to achieve level positioning on uneven terrain. The lightweight and durable carbon fiber tripod has a folded length of 17", yet weighs only 2.47 lb, making it easy to carry to any location. Threaded 1/4"-20 accessory sockets allow extension arms or studs to be mounted in order to attach lights, microphones, or other accessories.
 Item updated in the last 24 hours    FLM CB-38FTR Professional Series Ball Head
Available 2 following
Price: $240.00
Selling my FLM CB-38FTR Ball Head. Great ball head, solid metal construction, made in Germany. It takes a day of shooting to used to the tension method.
Key Features
Load Capacity: 55 lb
Max Height: 3.5"
Weight: 15.4 oz
360° Pan with Independent Pan Lock
Patented Tilt-Only Function
Tension Control
Reversible 1/4"-20 & 3/8"-16 Thread
Anti-Friction Cork Padding
The CB-38FTR Ball Head from FLM is a high capacity tripod head which features FLM's patented Tilt-Lock function and an independent 360° panning base.
The CB-38FTR stands 3.5" high and features a maximum load capacity of 55 lb, while weighing in at 15.4 oz. The dual lock design uses two separate knobs to control the movement of the ball and the 360° panning base, giving the user greater control. A separate tension knob adjusts the drag on the ball, allowing the user to slow or hasten the re-positioning of their camera. The FTR series also utilizes FLM's patented Tilt-Lock function which allows the user to lock the ball in all directions but one, allowing the ball to move along a straight line similar to a pan/tilt head.
The top mounting plate is covered in a friction reducing cork layer, which protects your equipment and prevents unwanted shifting and twisting. The top mounting thread is a reversible 1/4"-20 and 3/8"-16 stud which can be flipped to accommodate most cameras and camcorders.
Sep 21, 2021 at 01:59 PM
mj109
p.1 #2 · p.1 #2 · FS: FLM CP26-Travel Carbon Fiber Tripod + FLM CB-38FTR Professional Series Ball Head
up
Nov 20, 2021 at 02:08 PM
mj109
p.1 #3 · p.1 #3 · FS: FLM CP26-Travel Carbon Fiber Tripod + FLM CB-38FTR Professional Series Ball Head
bump
Dec 06, 2021 at 01:02 AM
Danplane
p.1 #4 · p.1 #4 · FS: FLM CP26-Travel Carbon Fiber Tripod + FLM CB-38FTR Professional Series Ball Head
I will pm you regarding the ball head.
Feb 03, 2022 at 09:59 PM
Bstrom2414
p.1 #5 · p.1 #5 · FS: FLM CP26-Travel Carbon Fiber Tripod + FLM CB-38FTR Professional Series Ball Head
Is the FLM ballhead still available?
Jan 11, 2023 at 02:44 PM
