c.d.embrey Offline Upload & Sell: Off
p.1 #9 · p.1 #9 · Is it possible to just buy a boom arm without a light stand? | |
rico wrote:
At half the weight, I would not call the D600 about the same. The spec'ed payload at full extension is 15 lbs, or right at your limit. I feel more comfortable operating a boom at well under its limit. The D650 comes with a 15-lb iron counterweight ($50 value), while the D600 needs an addition c/w solution.
I've worked as both a union grip, and a union lighting tech in Hollywood. I trust Matthews. If MSE says 15 lbs it will probably hold more than 15 lbs. This is why you won't find look-a-likes in use by the studios and rental houses in Los Angeles.
