Archive 2021 · Can anyone tell me what this is or what setting is causing this on A1?
Vtcats
p.1 #1 · p.1 #1 · Can anyone tell me what this is or what setting is causing this on A1?
I’m attaching an image showing a flashing expand flexible spot (if it was a gif, it would show flashing).
It’s not necessarily the focus mode selected and I can change to any focus mode but this still keeps flashing. Also, it doesn’t effect what mode I select when activating a focus mode, but as mentioned, just keeps flashing.
I know it has to be a setting because I have two other saved settings (in position 1 and 3) where this does not happen. I’ve tried looking at all my focus settings to see what’s different and only the release as opposed to balanced emphasis is different.
When I changed that to match the non flashing mode, it still kept flashing.
I supposed I can go through EVERY setting, but thought maybe someone might know
Apr 23, 2021 at 09:11 AM
StephenLowell
p.1 #2 · p.1 #2 · Can anyone tell me what this is or what setting is causing this on A1?
Try turning off the touch screen (just a hunch)
Apr 23, 2021 at 09:25 AM
snapsy
p.1 #3 · p.1 #3 · Can anyone tell me what this is or what setting is causing this on A1?
Don't own an A1 but searched for "flashes" in the online manual and found this:
https://helpguide.sony.net/ilc/2040/v1/en/contents/TP0002924532.html?search=Flashes
"When a focusing frame is registered using [AF Area Registration], the registered focusing frame flashes on the monitor."
Apr 23, 2021 at 09:27 AM
Vtcats
p.1 #4 · p.1 #4 · Can anyone tell me what this is or what setting is causing this on A1?
Bingo! Thank-you. I guess I should actually view the manual more when needed.
Apr 23, 2021 at 09:39 AM
