1       2       3              8              end
Archive 2005 · homemade macro solution
toonhorse
p.9 #1 · homemade macro solution
Is that some CA in your picture jaybussiere? Specifically, on the "35-80" lettering. Almost looks like it doesn't it?
Mar 03, 2005 at 10:21 AM
jaybussiere
p.9 #2 · homemade macro solution
sure is. I haven't tested it throughly but it's there. not sure about how it is in the center with contrasty areas. I'll post more results later with better lighting but impressed so far for a free macro lense.
Mar 03, 2005 at 10:25 AM
toonhorse
p.9 #3 · homemade macro solution
Yeah, a free macro is hard to beat. I wasn't using the 35-70 at all, now I keep it in my bag all the time. And the CA can always be corrected in PS if need be. So far I haven't noticed any in my photos but the 35-70 probably has different lens elements.....
Mar 03, 2005 at 10:28 AM
bellyface
p.9 #4 · homemade macro solution
update on that last 35-70 I just got "as-is" on ebay, well, I got it and fixed it. it appeared the guy somehow dropped it and bent the name plate, which on the old mark 1's was aluminum. So I pried it off, took the entire front end off, cleaned it (I know how to take them apart now) bent the ring back into shape, and voila, I have a late 80's 35-70 EF zoom. I have to say it's pretty sharp. Not amazing, but it's pretty decent for $24. They sure built those lenses better than today... so my quest for a banged 35-70 or 28-70 II (old style) will go on...
Mar 06, 2005 at 05:31 PM
tchotchke
p.9 #5 · homemade macro solution
About the reversed 50... here's another example. You can clearly see the vignetting and that the photo is not very sharp. Focusing is nearly impossible using this method and you have to get within inches of whatever you want to focus on. Sometimes the focus distance is less than 2 inches. Amazingly this guy didn't get scared away. It's actually from my first day discovering the technique!
http://img37.exs.cx/img37/7371/img34478zp.jpg
Mar 06, 2005 at 08:01 PM
LoneShadow
p.9 #6 · homemade macro solution
Are you folks using any particular type of flash ? 1-2inches is a lil too close for taking good pictures inside the house.
I should try some pictures outside during day time I guess.
LS
Mar 09, 2005 at 08:47 PM
MaxG
p.9 #7 · homemade macro solution
Brilliant find Bellyface, I'm gonna keep an eye open on ebay for some of these lenses, maybe you could make a list of lenses which you know this works with, would be real helpfull!!!
Kind regards,
Max G.
Mar 13, 2005 at 04:56 AM
bellyface
p.9 #8 · homemade macro solution
Thanks Max! Well I used it in the studio, turned my wattage up just to get in the F11-22 range. Speed was pretty much 1/250th.
Mar 13, 2005 at 01:43 PM
bellyface
p.9 #9 · homemade macro solution
I think any of the short zooms, minus the 35-105's....
Mar 13, 2005 at 01:44 PM
bellyface
p.9 #10 · homemade macro solution
took some shots today... horse flies are everywhere...
this one is about to split...
http://www.ivanaguiar.com/IMG_7127.jpg
this one split as soon as the shutter went off...
http://www.ivanaguiar.com/IMG_7130.jpg
can anyone guess what this is?
http://www.ivanaguiar.com/IMG_7163.jpg
these images were not cropped... this is 100% of the actual frame, just rezed down.
Mar 14, 2005 at 02:55 AM
jaybussiere
p.9 #11 · homemade macro solution
looks like a hairbrush to me.
Mar 14, 2005 at 04:40 AM
bellyface
p.9 #12 · homemade macro solution
rusty wire brush
Mar 14, 2005 at 10:21 AM
zakooldude
p.9 #13 · homemade macro solution
Barbecue brush. I've done plenty of those myself.
Great post to whoever discovered this method. I took the liberty of posting a link to this thread at DSLR:
http://www.dslreports.com/forum/remark,12900258~mode=flat
I did something recently that I should post about here - I ended up making a bi-convex lens in our university optical grinding lab, and I taped it to the front of my 50mm f/1.8 II, it makes one hell of a macro lens! Probably somewhere in the realm of 2:1 magnification.
Mar 14, 2005 at 01:35 PM
bellyface
p.9 #14 · homemade macro solution
I'm speechless....
Mar 14, 2005 at 02:01 PM
bellyface
p.9 #15 · homemade macro solution
Well, pretty soon, you'll be able to download the complete diagrams and details on how to convert your subpar lenses....
http://www.mistermacro.com/
for the time being, I will be working on the details and most likely will be taking donations... cause I'm poor
but love photography....
Mar 14, 2005 at 02:34 PM
toonhorse
p.9 #16 · homemade macro solution
Awesome bellyface, looking forward to checking that site out once it's up. I have quite a few sample shots with the 35-70 that you can add to it, if that's the kind of thing you want to do. Also, I can take a picture of my lens, so people can have an example of what it will look like. I wish i had taken better notes when i took it apart.....let us know when that site is functional!
Mar 14, 2005 at 02:49 PM
inescapable
p.9 #17 · homemade macro solution
Incredible discovery. The thread is getting a bit long to read through the hole thing, but i just found it.
im wondering if there is a summary somewhere of lenses that you can do this with/how to do it.
Mar 14, 2005 at 10:18 PM
unclebobo
p.9 #18 · homemade macro solution
Thanks bellyface, you just saved me the horrible mistake of putting my old 35-80 on flea-bay...whew, that was close
Mar 15, 2005 at 02:31 AM
elkootcho
p.9 #19 · homemade macro solution
Found a 35-80 on ebay for $25 and quickly took it apart. Unfortunately I had to be right on top of my subject to focus so I used bellyface's technique to gain a few inches of working room. Here's my first result. This is a little league baseball that is about 20 years old.
Full frame:
http://www.mastersofprint.com/baseball_fullframe.jpg
100% Crop:
http://www.mastersofprint.com/baseball_crop.jpg
Mar 24, 2005 at 12:08 AM
elkootcho
p.9 #20 · homemade macro solution
Thanks for sharing this mod, bellyface. I love it. All the fun with none of the expense. Here's one more. This lovely item is a $3 Empire State Building souvenir (sp?). My favorite keepsake from a day trip to New York City last fall.
Full frame:
http://www.mastersofprint.com/building_full.jpg
100% crop:
http://www.mastersofprint.com/building_crop.jpg
Mar 24, 2005 at 12:31 AM
1       2       3              8              end
1       2       3              8              end
