       2       3              8       9       end
Pre-order: Sigma 28-70mm F2.8 DG DN Contemporary ($899)
Admin
p.1 #1 · p.1 #1 · Pre-order: Sigma 28-70mm F2.8 DG DN Contemporary ($899)
Update: Pre-order now available
B&H Photo | Adorama
Main Specs:
  1. Focal Length 28 to 70mm
  2. Maximum Aperture f/2.8
  3. Minimum Aperture f/22
  4. Lens Mount Sony E
  5. Format Compatibility Full-Frame
  6. Angle of View 75.4° to 34.3°
  7. Minimum Focus Distance 7.5" / 19 cm
  8. Maximum Magnification 3.3 to 4.6x
  9. Optical Design 16 Elements in 12 Groups
  10. Diaphragm Blades 9, Rounded
  11. Focus Type Autofocus
  12. Image Stabilization No
  13. Filter Size 67 mm (Front)
  14. Dimensions (ø x L) 2.8 x 4" / 72.2 x 101.5 mm
  15. Weight 16.6 oz / 470 g
________
Nokishita just reported that the "Sigma's "28-70mm F2.8 DG DN Contemporary" compact zoom lens has been added to overseas retailers"
It looks like the official announcement is imminent.
https://twitter.com/nokishita_c/status/1362524472545210370
Update: Leaked images showing the new Sigma 28-70mm F2.8 DG DN Contemporary added
Feb 18, 2021 at 11:19 PM
Douglas Liu
p.1 #2 · p.1 #2 · Pre-order: Sigma 28-70mm F2.8 DG DN Contemporary ($899)
I just bought the Sony 28-60mm... Will be interesting to see what this Sigma is all about.
Feb 18, 2021 at 11:46 PM
fotografur
p.1 #3 · p.1 #3 · Pre-order: Sigma 28-70mm F2.8 DG DN Contemporary ($899)
Sigma is killing it 📷
Feb 18, 2021 at 11:58 PM
chez
p.1 #4 · p.1 #4 · Pre-order: Sigma 28-70mm F2.8 DG DN Contemporary ($899)
Totally different lenses. Big thing Sigma would have going for it is 2.8 instead of 4-5.6. You can use the Sigma indoors...not so much with the Sony.
Feb 19, 2021 at 12:11 AM
Douglas Liu
p.1 #5 · p.1 #5 · Pre-order: Sigma 28-70mm F2.8 DG DN Contemporary ($899)
I already have the Sigma 24-70, it's a bit heavy but i like it a lot. I am looking at this new Sigma mainly with a passing interest.
Feb 19, 2021 at 12:18 AM
stevenvh
p.1 #6 · p.1 #6 · Pre-order: Sigma 28-70mm F2.8 DG DN Contemporary ($899)
Thanks Fred. This will be very interesting. I'm currently resisting the Tamron 28-75 and hoping Sigma can shrink theirs just a little bit more.
Feb 19, 2021 at 12:23 AM
Charlie N
p.1 #7 · p.1 #7 · Pre-order: Sigma 28-70mm F2.8 DG DN Contemporary ($899)
If 1” shorter than the tamron, will preorder.
Feb 19, 2021 at 12:43 AM
kroyston
p.1 #8 · p.1 #8 · Pre-order: Sigma 28-70mm F2.8 DG DN Contemporary ($899)
Figures, I just picked up a Tammy 28-75 off B&S. Really though, I doubt the Sigma will be any lighter, which was the primary consideration for choosing the Tammy in the first place.
Edited on Feb 19, 2021 at 01:39 AM · View previous versions
Feb 19, 2021 at 01:32 AM
derKoekje
p.1 #9 · p.1 #9 · Pre-order: Sigma 28-70mm F2.8 DG DN Contemporary ($899)
I would miss the 4mm on the wide end too much but if it’s smaller than the Tamron and provides better bokeh then I may still be interested.
Feb 19, 2021 at 01:35 AM
gocolts
p.1 #10 · p.1 #10 · Pre-order: Sigma 28-70mm F2.8 DG DN Contemporary ($899)
This lens still confuses me considering they have the 24-70 2.8...although maybe they found a way to make it so much smaller that it'll be a tempting alternative for some.
Feb 19, 2021 at 01:37 AM
nhsonyshooter
p.1 #11 · p.1 #11 · Pre-order: Sigma 28-70mm F2.8 DG DN Contemporary ($899)
If they make this smaller than the Tamron somehow it would pair nicely with my 20mm 1.8. Just make it 67mm and I'll take one
Edited on Feb 19, 2021 at 02:48 PM · View previous versions
Feb 19, 2021 at 03:41 AM
flower_power
p.1 #12 · p.1 #12 · Pre-order: Sigma 28-70mm F2.8 DG DN Contemporary ($899)
I'd love to see a great and compact 24-105 f4 from them...
Feb 19, 2021 at 04:09 AM
trogdon
p.1 #13 · p.1 #13 · Pre-order: Sigma 28-70mm F2.8 DG DN Contemporary ($899)
Nokishita just posted images, looks pretty compact but it’s hard to tell exactly. Has a 67mm thread, so I am guessing it’ll be very close in size to the Tamron 28-75
Feb 19, 2021 at 01:50 PM
fjablo
p.1 #14 · p.1 #14 · Pre-order: Sigma 28-70mm F2.8 DG DN Contemporary ($899)
Just eyeballing but it might be a bit shorter - around 10cm?
Feb 19, 2021 at 02:12 PM
Douglas Liu
p.1 #15 · p.1 #15 · Pre-order: Sigma 28-70mm F2.8 DG DN Contemporary ($899)
I am not seeing any switches, I hope Sigma is not following Tamron's suit by not even including an AF/MF switch.
Feb 19, 2021 at 02:33 PM
nhsonyshooter
p.1 #16 · p.1 #16 · Pre-order: Sigma 28-70mm F2.8 DG DN Contemporary ($899)
It does look more compact. Hope they got the sealing part sorted, not a fan of internal dust. It is 67 which is great.
Feb 19, 2021 at 02:42 PM
nhsonyshooter
p.1 #17 · p.1 #17 · Pre-order: Sigma 28-70mm F2.8 DG DN Contemporary ($899)
Look directly under the C it looks like you may see the profile of a switch?
Feb 19, 2021 at 02:45 PM
GMPhotography
p.1 #18 · p.1 #18 · Pre-order: Sigma 28-70mm F2.8 DG DN Contemporary ($899)
If not it’s a complete no go for really any A7C owner as we are pretty limited to custom function switches. The Af/MF switch on lens really helps with actually adding that custom switch. If that’s true I’m out at least. I cannot shoot AF only , I need both as I never trusted AF only
tsdevine
p.1 #19 · p.1 #19 · Pre-order: Sigma 28-70mm F2.8 DG DN Contemporary ($899)
Looks like it to me, in the second photo. It also is in the spot that would be consistent with the other Contemporary lenses.
-Tim
Feb 19, 2021 at 02:54 PM
SoundHound
p.1 #20 · p.1 #20 · Pre-order: Sigma 28-70mm F2.8 DG DN Contemporary ($899)
Sigma’s not noted for plastic which is how you save weight these days. I too depend on the wide end of my Sony 24-70 F 2.8 for 24mm. Rather get the 28-60mm tiny zoom if I accept the narrower wide end.
Feb 19, 2021 at 03:03 PM
       2       3              8       9       end
       2       3              8       9       end
Username      Reset password
