Archive 2020 · Anomalous Sandstone Beds in the High Southern Olympic Mountains
Laurence_Smith
p.1 #1 · p.1 #1 · Anomalous Sandstone Beds in the High Southern Olympic Mountains
Off trail in the high southern Olympic National Park.
Exposed sandstone bedrock intrusions like this are found only in scattered areas in the Olympic Mountains.
Research tells me that this is possibly a small batholithic plateau that was part of an ancient seabed that was pushed up and rotated into the Olympic Mountains massif.
It was an interesting departure from the usually dark gray to black rocks that are prevalent in the Olympic range.
My route took me down, then up and over the distant ridgeline, and then west (left) on the other side, for three days of traversing meadows and lakes, all in pristine, beautiful subalpine terrain. Eventually intersected a trail two valleys away.
No indication of human presence, which added to the charm of the trip.
Fuji GX680 (I cuss out this beast of a camera a lot, especially packing it off trail. But it's okay, no one hears me).
65/5.6 lens
Provia film
Dec 01, 2020 at 03:49 PM
junglialoh
p.1 #2 · p.1 #2 · Anomalous Sandstone Beds in the High Southern Olympic Mountains
background help to emphasize foreground subject well,
but foggy environment does not help greatly IMO. nice composition.
Dec 01, 2020 at 04:14 PM
SergeyT
p.1 #3 · p.1 #3 · Anomalous Sandstone Beds in the High Southern Olympic Mountains
Very beautiful scene and extraordinary conditions! Light like that does not happen too often.
I cant help but wonder what is there where the dried stream is coming from. Apparently a lake? Wish you could put the viewer just a few steps to the right from where your camera was.
And BTW, a 4x5 field with 2 lens and a 6x9 or 6x12 roll back could help you to significantly reduce the weight of your gear without obvious sacrifices elsewhere.
Dec 01, 2020 at 11:12 PM
Laurence_Smith
p.1 #4 · p.1 #4 · Anomalous Sandstone Beds in the High Southern Olympic Mountains
Thanks SergeyT. Actually, the scene falls downhill and away from the camera, although I can see why you wondered about there possibly being a lakelet or other water source, because it's difficult to tell what the slope is doing.
Regarding the camera weight, this is actually the last year for using the GX680. I have several hundred transparencies from the beast, and it's time to change venues. I definitely have been considering a large format field unit with a couple of rollfilm back sizes. Could probably cut off at least 50% of the weight.
Dec 02, 2020 at 01:31 AM
