Fred Miranda Offline Admin Upload & Sell: On
| p.1 #1 · p.1 #1 · Pre-order: Tamron 70-300mm f/4.5-6.3 Di III RXD Lens for Sony E | |
The new is now available for pre-order for $549:
B&H Photo | Adorama
__________
With a dynamic telephoto zoom range and compact profile, the 70-300mm f/4.5-6.3 Di III RXD Lens for Sony E from Tamron provides a popular telephoto zoom range for the full-frame Sony E-mount mirrorless cameras. This lens spans a useful short- to long-telephoto range and is a small and light 70-300mm zoom lens, measuring just 5.8" in length with a maximum diameter of 3", and it weighs just 1.2 pound. It offers optical performance with aberration correction that delivers high image quality. Tamron's RXD stepping motor unit provides high-speed, high-precision, and quiet operation and also takes full advantage of in-camera features, including Sony's Fast Hybrid AF and Eye AF functions. The 70-300mm f/4.5-6.3 is a highly-practical telephoto zoom lens that performs across a diverse range of shooting styles including, sports and other athletic events, wildlife, portraits, and more.- Versatile telephoto zoom is designed for full-frame Sony E-mount mirrorless cameras, however can also be used with APS-C models where it will provide a 105-450mm equivalent focal length range
- RXD stepping motor unit provides high-speed, high-precision, and quiet operation that takes full advantage of in-camera features, including Sony's Fast Hybrid AF and Eye AF features
- A moisture-resistant construction benefits this lens' use in inclement conditions
Specifications:- Model A047
- Focal Length 70-300mm
- Maximum Aperture F4.5-6.3
- Angle of View (diagonal) 34°21'-8°15' (for full-frame mirrorless format)
- Optical Construction 15 elements in 10 groups
- Minimum Object Distance 0.8m /31.5 in (WIDE), 1.5m /59.1 in (TELE)
- Maximum Magnification Ratio 1:9.4 (WIDE) / 1:5.1 (TELE)
- Filter Size φ67mm
- Maximum Diameter φ77mm
- Length* 148mm (5.8 in)
- Weight 545g (19.2 oz)
- Aperture Blades 7 (circular diaphragm)**
- Minimum Aperture F22-32
- Standard Accessories Round-shaped hood, Lens caps
- Compatible Mounts Sony E-mount
Date of Launch: October 29th, 2020
Tamron's Press Release | Lens Official page
