ZhanMing12 Offline Upload & Sell: Off
zhangyue wrote:
I had X1DII, peaking is the worst I ever used in recent year, you can't trust it at all given too many stuff will be highlighted. (I no longer have Sony system, so my memory is mainly compare to SL2 and S1 Z7) However, it can certainly be used as guide for DOF. Other system usually let you select peaking sensitivity at least.
Focus by Wire is also worst I ever used. It is not usable per my standard. I had 21 and 80. I didnt use 21 much. But 80 otherwise would be one of best lens if I can at least use its manual focus well which I can't. My major complain is focus response delay and fine tune resolution. This is definitely worst FBW, nothing as bad.
Ergo and Menu are the best you can get. Very comfortable to hold, pleasing to view. For landscape or city even controlled portrait session, it is a good system. For some, it might be able to serve as sole system. The biggest flaw is I can't really adapt any glass on it, 1/3s read out is actually still usable because that is whole sensor read out spec. (E-shutter is read out line by line.) The problem is delay and black out with each click, 2~3s? I don't mind either Manual focus or Auto Focus, but I mind half baked AF which cant be used as manual focus, if Leica S AF get a 4 out of 10 due to focus accuracy, it at lest gets 8/10 for real focus ring implementation. this one is get about the same for AF with motor vibration, sloppiness, and back focus often but get 1~2 out of 10 for manual focus implementation. I mainly talk about 80mm, I guess there are lots of glasses inside need to be moved. I don't have experience on 45/30/90.
If you like the idea of this system, then my writing will not scare you away anyway. Especially answer to most of your question are it can As I mentioned this is one of best implementation for control, menu and ergo.
Edit: I also want to add its EVF looks big and bright, however glass design is poor, anything away from center looks not sharp. This is another flaw for manual focus users. Not a problem for many I am sure, but want to mention. ...Show more →
Thanks for the writeup. I don't plan on using the 80mm (or the 21) in the foreseeable future, given the cost of those optics I would probably opt to just keep a Sony body to shoot fast tele's and reserve the X1d ii for 25-70mm.
I don't recall the EVF being anything less than excellent though, have you tried any other copies of the body to see if it was a hardware issue?
