Fred Miranda Offline Admin Upload & Sell: On
p.1 #1 · p.1 #1 · Pre-order: Sigma 100-400/5-6.3 DG DN OS FE ($949!) | |
Sigma officially released the 100-400mm f/5-6.3 DG DN OS lens and it's now available for pre-order for $949:
B&H Photo | Adorama
It has an array of low-dispersion glass that helps to reduce color fringing and chromatic aberrations throughout the zoom range, as well as realize accurate color and reduce flaring. Among other features, one of the most welcome will be the inclusion of optical image stabilization, which compensates for up to four stops of camera shake. This OS system can be used in conjunction with camera-based in-body image stabilization, too, for even more robust support to aid making sharp handheld images.
Features:- As part of the Contemporary line within Sigma's Global Vision series, this lens is designed to achieve a balance between convenience and performance, and meshes a compact, lightweight build and versatile handling with notable optical attributes.
- Telephoto zoom is designed for full-frame Sony E-mount mirrorless cameras, but can also work with APS-C models where it provides a 150-600mm equivalent focal length range.
- One F Low Dispersion (FLD) element and four Special Low Dispersion (SLD) elements markedly reduce chromatic aberrations and color fringing throughout the zoom range for improved clarity and color accuracy.
- Optical image stabilization compensates for up to four stops of camera shake to help realize sharp imagery when shooting handheld with slower shutter speeds.
- Integrated stepping motor realizes quick and quiet autofocus, which is further complemented by an optimized AF algorithm to produce smoother focusing performance.
- At the 100mm end of the zoom range, a minimum focusing distance of 3.7' is available, and at the 400mm end, the minimum focusing distance is 5.2' with a maximum magnification of 1:4.1.
- Integrated AFL button can be programmed to adjust various shooting settings and the lens also features a focus limiter switch for faster focusing performance within certain distance ranges. There is a zoom lock switch to prevent the barrel from accidentally extended.
- Rounded 9-blade diaphragm contributes to a pleasing bokeh quality.
- Brass bayonet affords improved mounting accuracy and rigidity and rubber sealing is incorporated in the mount's design to render it dust- and splash-resistant.
- Compatible with optional TS-111 Tripod Socket for working atop a tripod or monopod; the included PT-31 Protective Cover can be attached to the lens to maintain a seamless appearance if the tripod socket is not used.
Main Specifications:- Focal Length 100 to 400mm
- Maximum Aperture f/5 to 6.3
- Minimum Aperture f/22 to 29
- Lens Mount Sony E
- Format Compatibility Full-Frame
- Angle of View 24.4° to 6.2°
- Minimum Focus Distance 3.61' / 1.1 m
- Maximum Magnification 0.24x
- Optical Design 22 Elements in 16 Groups
- Diaphragm Blades 9, Rounded
- Focus Type Autofocus
- Image Stabilization Yes
- Tripod Collar Removable and Rotating (Optional)
- Filter Size 67 mm (Front)
- Dimensions (ø x L) 3.39 x 7.76" / 86 x 197.2 mm
- Weight 2.5 lb / 1135 g
Full features and specifications at Sigma.com | B&H Explora article
