Archive 2020 · 40-45mm
AdaptedLenses
p.1 #1 · p.1 #1 · 40-45mm
Debating the various wide-ish normal for Sony, focused on the AF options. I think I’ve deciphered the Sigma / Samyang debate, generally smoothness vs sharpness with a bit of AF issues sprinkled in. What I’m wondering, is how does the Batis 40 fit in after it’s release woes? To be honest I generally find the samples from that lens most compelling though all do well in capable hands. Is it the size and price? Otherwise, what’s the current thoughts on the options?
Feb 23, 2020 at 10:14 PM
wdshuck
p.1 #2 · p.1 #2 · 40-45mm
I have the Batis 40 and have been very happy with it. I bought it after they updated the firmware and haven't had any issues. Very fast AF, sharp across the frame from wide open.
I think most were turned away from the Batis 40 because of the initial Eye AF issues (and maybe the stopping down at close distances). Once Zeiss finally sorted things with updated firmware, the Sigma and Samyang had come out. At that point, most didn't see the reason to pay the higher price for the Batis, since the other lenses were <50% the price and offered most of the performance.
Feb 24, 2020 at 06:47 AM
Bob_S
p.1 #3 · p.1 #3 · 40-45mm
The Sigma 40 Art > the Batis by a slight but noticeable margin in terms of performance, also, price.
Rendering is subjective, I prefer either/neither.
Feb 24, 2020 at 06:49 AM
KarmaKramer
p.1 #4 · p.1 #4 · 40-45mm
All things considered. Batis probably offers better quality and reliability over all the usual Sigma/Samyang snags.
The whole Batis line is pretty great.
Feb 24, 2020 at 07:04 AM
AdaptedLenses
p.1 #5 · p.1 #5 · 40-45mm
Thanks. Sigma Art is beautiful I'm sure but no desire to carry that. Batis is on the upper limit of size...
Thanks for thoughts.
Feb 24, 2020 at 10:51 AM
darrellc
p.1 #6 · p.1 #6 · 40-45mm
Had the Batis 40 pre and post firmware and two copies of it. Have Sigma 45 now.
Batis 40, if you get a good copy (my first copy couldn’t AF accurately, Zeiss confirmed and replaced under warranty) and update to latest firmware is pretty good in terms of AF.
I tested it fairly extensively against my FE 35/1.8 for my primary use cases - shooting my kids at 0.75-2m and for video of same and ended up switching to the FE 35/1.8.
I found the FE 35/1.8 was smoother and more confident (less hunting) in focus transitions for video and had much less focus breathing (almost none compared the quite evident breathing on the Batis). But the Batis wasn’t bad relative to many lenses, just noticeably worse than the FE 35/1.8.
For stills, I tested eye AF in AF-C and shot a bunch with both lenses. I’d say the FE 35/1.8 nailed eye autofocus on average 9/10 shots and the Batis 40 nailed it maybe 7.5/10 shots. No difference in AF-S and no difference beyond the 3-5 feet or so distance i was testing for head and upper torso portraits. Note that the FE 35/1.8 is the best native AF lens I’ve ever had (haven’t had the GM 135 but most of the rest) so the Batis is pretty good. If I shot only stills I’d have kept the Batis. That being said, I do like the confidence I get with the FE 35/1.8 in stills and esp. in video.
The Batis is a better lens than the FE 35/1.8 for stills in terms of IQ, especially wide open (Batis pretty sharp edge to edge even at f/2). Much better color correction with the Batis, no coma, etc. And build quality seems much, much better than the FE 35/1.8. I don’t have much confidence in the weather sealing of the FE 35/1.8. I’ve never had problems with Batis lenses in bad weather and Zeiss is fairly transparent about the testing they do for dust and moisture and seems robust (you can find articles on Batis testing by Zeiss). Bokeh can be wonky on both lenses, I can invoke horrible bokeh on both. I’d say that the FE 35/1.8 may have preferable bokeh at short to medium distances, but both break down with complex backgrounds like foliage.
In any case, I use this focal length for video a lot so I decided to let go of the Batis and use the FE 35/1.8. Not sure if it was the right decision, but looks like you can buy a used Batis 40 for cheap.
Sigma 45 is totally different. AF-C accuracy no where near Batis or FE 35/1.8, and you have to stop down to f/4 near MFD (it reminds me of the X100 lens in terms of how you manage sharpness at closer distances). AF accuracy also drops in low light compared to the other lenses. But a gorgeous look and super sharp stopped down. I found the FE 35 and Batis 40 were both quite punchy contrasty, so pleasing much of the time across a lot of subjects, but I do prefer the smoother, more “organic” look of the Sigma (reminds me of the GM look vs. the traditional Zeiss look).
Feb 24, 2020 at 12:00 PM
ryanli
p.1 #7 · p.1 #7 · 40-45mm
Sorry I can't comment on the Batis, but you are spot on with the Sigma Vs Samyang comparison (price and value for money notwithstanding)
Feb 24, 2020 at 01:01 PM
Frogfish
p.1 #8 · p.1 #8 · 40-45mm
For the price of the Batis you can literally buy both of the Samyangs in that range (45/1.8 and 35/1.4) for the best of all worlds. I really liked my Batis 85 but the Samyang runs rings around it for my uses and it's likely those two lenses over the one would give you far more options no matter if the Batis shades them in some areas.
Feb 24, 2020 at 01:08 PM
AdaptedLenses
p.1 #9 · p.1 #9 · 40-45mm
Had the Samyang before I left Sony about a year ago... Not going that large again though I agree its rendering was quite nice.
On here we debate all day about rendering but 98% of our viewers can't tell the difference, the image is good or not good. So I do want the best IQ, within my own constraints which includes not carrying boat anchors. No argument with those that do chose to carry them, they have their value to be sure, but not for me.
Feb 24, 2020 at 01:44 PM
