rvh23 Offline Upload & Sell: Off
| p.1 #1 · p.1 #1 · Improved focus stacking MF accuracy with Sony's integer distance readout | |
Having recently evaluated the new Sigma 14-24 DG DN zoom, I have been looking at how best to manual focus this focus-by-wire lens for focus stacking. Unfortunately it has a non-linear focus mechanism that changes the lens throw according to how fast you turn the focus ring. So you can't easily use angular increments to set your stack focal points. And even more unfortunately the distance readout in Sony cameras (to date) switches to integers beyond 1m. Importantly though, the exif data retains far more accuracy, and from my limited testing with this particular lens seems to correspond reasonably well to real-world best focus distance. Certainly more so than the integers in the display.
In trying to find a more reliable way to use Sony's distance readout, I think I may have found something that helps.It turns out that with this lens, and I suspect others also, that although the integer readout is very inaccurate due to rounding, the distance at which the integer increments is highly repeatable according to the exif data.
I did three repeats of finding the display toggle point between "1m" and "2m", both at 14mm and 24mm focal lengths on the zoom, and took a shot at each adjustment. The exif data showed it was very close to 1.4m in all cases. Similarly, the toggle-point between "2m" and "3m" in the display was always very close to 2.5m in the exifs, and the one between 0.9m and 1m was always at 0.9m.
In other words, I can know the lens is focused very close to 0.9m, 1.4m, and 2.5m if I carefully find the associated toggle-points at 0.9-1m, 1m-2m, and 2m-3m, respectively.
You can find other toggle points according to your typical interests, but for me I think these distances in particular will be very helpful in stacking typical landscape scenes.
It might be interesting to know, if anyone has the inclination, whether the same method can be used with other lenses that send distance information to the camera.
