The Milky Way and airglow over the San Juan Mountains in Colorado - FM Forums
Archive 2019 · The Milky Way and airglow over the San Juan Mountains in Colorado
DanielJStein
p.1 #1 · p.1 #1 · The Milky Way and airglow over the San Juan Mountains in Colorado
It's been a minute since I last posted on the Forum. I finally cooked up enough courage and content to become active again. This is an image I took on an early June adventure to Colorado.
This is a 2 image blend taken with my star tracker. Nikon Z6 with an h-alpha mod and Nikkor 14-24 f/2.8 were used. One shot tracked for the stars, one shot untracked for the foreground taken in direct sequence with no further adjustments to where the camera was facing. The tracked shot was taken at f/2.8, ISO 800, 2 minutes. The untracked at f/2.8, ISO 800, 6 minutes.
I used LR for cataloging and lens corrections, Pixinsight for the bulk of processing, and Photoshop for the blending and final touches. CC welcome!!
Aug 11, 2019 at 03:57 PM
dakel
p.1 #2 · p.1 #2 · The Milky Way and airglow over the San Juan Mountains in Colorado
Very nice. Incredible detail in the Milky Way
Aug 11, 2019 at 07:03 PM
DanielJStein
p.1 #3 · p.1 #3 · The Milky Way and airglow over the San Juan Mountains in Colorado
Thank you!
Aug 12, 2019 at 03:00 AM
RoseandCharles
p.1 #4 · p.1 #4 · The Milky Way and airglow over the San Juan Mountains in Colorado
Beautiful. How many planes/satellites did you have to remove?
I haven't used pixinsight but I've heard a lot of astro pros use it. Is it pretty straightforward to learn, and better than lightroom/photoshop?
Aug 13, 2019 at 11:20 PM
bmike-vt
p.1 #5 · p.1 #5 · The Milky Way and airglow over the San Juan Mountains in Colorado
Yes, so glad to see the work here and larger than in the postage size IG!
Aug 14, 2019 at 01:44 AM
DanielJStein
p.1 #6 · p.1 #6 · The Milky Way and airglow over the San Juan Mountains in Colorado
Thank you! Believe it or not, no planes or satellites needed to be removed from this. Typically if a plane/satellite is caught in my shot, I will wait for it to pass and reshoot. Alternatively, I may shoot a stack sequence of 10 or so images, and the stacking algorithm will cancel it out. For this shot, I took 3 images. The first 2 had planes, but this shot was clear, so I just processed the one frame.
Pixinsight is quite daunting to use at first as it works quite differently to the typical sliders and curves found in LR or PS. Its tools are strictly focused on astrophotography and has some absolutely exceptional features just for the field that you would need to spend hours of tweaking to match what a single adjustment can do in Pixinsight in some cases. I am still learning as I go, as I am sure I probably know a good 10% of the software—if that... This all said, the internet is the resource I have been using for processing tutorials, and there sure is a plethora of them!
Aug 14, 2019 at 04:47 AM
DanielJStein
p.1 #7 · p.1 #7 · The Milky Way and airglow over the San Juan Mountains in Colorado
Thank you! Too bad it is still all compressy though
Aug 14, 2019 at 04:48 AM
