DannyBurkPhoto Offline Upload & Sell: Off
p.1 #3 · p.1 #3 · Adapting the new Laowa 100/2.8 2:1 macro - Nikon mount to Canon mount | |
freaklikeme wrote:
I wouldn't count out the MC21. Aperture control is relatively standard, so it may work. If it were an AF lens and you expected AF to work, you'd probably be in more trouble.
You don't want an adapter with the aperture behind the lens. It doesn't work the same way an in-lens aperture works and will cause mechanical vignetting stopped down. Nikon has had lenses with aperture rings that are mechanically coupled for a long time. Nikon has also had "G" series lenses that are mechanically coupled and there are adapters that give you some control over that coupling. Nikon "E" lenses (105/1.4, 200-500/5.6, etc) are full electronic and require one of the more sophisticated adapters. So, as long as the Laowa isn't fully electronic, and there is an aperture ring on the lens, you should be fine with a dumb adapter....Show more →
The lens arrived today, and I'm glad to report that it works fine with the dumb Nikon-Canon adapter, as you expected it would. So much for someone's comment (not on FM) that it can't close the aperture manually. Since it works fine, I'll just keep this one; if it hadn't, I'd probably have sent it back to exchange for a Canon mount version and try my luck with the Sigma adapter.
I was hoping that it would also cover the GFX sensor at close range. It sort of does...at 1:1 or higher, only the very tips at the corners vignette. It may not be hard vignetting - I won't know till I try a test and bring it up in ACR. Even if they're not removable, it would only take a tiny crop or slight cloning to get rid of them.
