gdanmitchell Offline Upload & Sell: Off
p.1 #5 · p.1 #5 · Problem creating B&W profile with i1Profile + ColorMunki + MacOS | |
I'm back, partly to respond to Peter's question and partly to make sure that what I've learned becomes part of the data here at FM.
First, Peter, I'm actually using i1Studio (not "i1Profiler"), and yes there is an option (at least on my MacOS version of the i1Studio software) to produce separate color and black & white paper profiles. As near as I can tell, both begin by producing the very same initial one-page profiling test chart. Then, after building new profiles following a scan of that chart, the software generates a new two-page profiling test chart during the black and white process. (It generates a single page second profiling test chart for color, as counter-intuitive as that seems.)
The issue is that the i1Studio seems to be unable to print the second page of the two-page second profiling test chart. I was initially using sheet paper, and no convolutions that I could come up with would get it to print the second page. The first response from X-Rite support was to ask if I was loading two sheets of paper. You can't actually do that with the P9000 — it simply feeds both sheets, one atop the other, as if it were a single sheet. I wrote back and pointed this out.
While waiting I thought I'd try with roll paper, since printing a second page shouldn't require "two sheets" to be loaded. I was optimistic... but I ended up with exactly the same problem — I could only print the first profile test chart page.
I was about to write back and report this to them when I got another email. The support person suggested that I print the .tif files produced by clicking the "Save Session" button, using Photoshop to print the pages separately. So, I was able to open the files for the two pages independently and print them — letting the printer manage colors so as to not impose any Photoshop profiles on the process.
Soooo... for now it seems that the answer is to go through the process in i1Studio, but not to print the two second profiling pages in the black and white profiling process from inside the software... but to instead open the generated .tif files for the two pages and print them out of Photoshop with the printer manage the colors.
