lighthound Offline Upload & Sell: Off
jcolwell wrote:
You could run chkdsk or similar app, to see if there's any corrupt files in the folder.
Thanks Jim, I'll give this a try.
fredmaurer wrote:
Since you have installed a fresh copy of DPP, it seems the issue is within that particular folder. Have you removed some of the images from that folder to try and isolate the problem images? If you are running a Mac, try "Disk Utility", then run "First Aid" on the disk. As jcolwell suggested, I would then run "Disk Warrior", or similar program, to check the files and folders for damage and potential compatibility issues. Good Luck!
Thanks Fred. After I try Jim's suggestion (Win 10) and if that doesn't work then removing any edited TIFF or PSD files will be my next option.
