sirimiri Offline Upload & Sell: Off
It's a bit slow to use in practice, but there is a Kipon adapter which is more or less a clone of the Cambo CA-GFX adapter that has a very wide throat, only obstructed by the EF contact pinset.
Kipon GFX-EF-E
Or, just opt for any of the "smart" adapters that allow you to control the aperture on your TS-E 24mm II. The baffles are more extensive than the GFX-EF-E adapter, I can't tell you if there's a difference when shifting the lens vertically as I don't know.
Kipon GFX-EF AF
The cost differential between the above is under 12% so choose what you think works best. Or order both and eat the return shipping on the one you don't like.
