tonyespofoto Offline Upload & Sell: Off
Something you might not think of because it does seem counter-intuitive, is that the tool works best with hardness set at 100%. If you reset the tool, you will find that a hard-edged brush is the default. As a rule, I do any retouching on a separate layer. There are also 3 choices: content aware, proximity match and create texture. Content aware is the most useful, but depending on the subject matter you are retouching, the other choices can also be useful. I've also found that the tool does the best job when used with short strokes. It's tempting when retouching for example a power wire across the sky, to just stroke the whole wire, but in my experience, the tool does a better job if short strokes are used.
