       2       3              17       18       end
Now in Stock: Sigma 35/1.2 Art, Sigma 45/2.8 and Sigma 14-24/2.8
Admin
p.1 #1 · p.1 #1 · Now in Stock: Sigma 35/1.2 Art, Sigma 45/2.8 and Sigma 14-24/2.8
Now in Stock: Sigma 45/2.8 FE, Sigma 14-24/2.8 FE, Sigma 35/1.2 FE
Update:
  1. Sigma 35mm f/1.2 FE now in stock at B&H Photo | Amazon ($1,499)
  2. Sigma 45mm f/2.8 FE now in stock at B&H Photo | Amazon ($549)
_________________
Pre-orders now open for the new Sigma FE lenses!
Sigma 35mm f/1.2 FE at B&H Photo | Adorama | Amazon ($1,499)
35mm F1.2 DG DN | Art Main features:
  1. E-Mount Lens/Full-Frame Format
  2. Aperture Range: f/1.2 to f/16
  3. Three Aspherical & Three SLD Elements
  4. Macro Reproduction Ratio 1:5.1
  5. Minimum Focus Distance 11.81" / 30 cm
  6. Optical Design 17 Elements in 12 Groups
  7. Hyper Sonic Motor AF System
  8. Customizable AFL Button
  9. Physical Aperture Ring; De-Click Switch
  10. Rounded 11-Blade Diaphragm
  11. Weather-Sealed, Protective Front Coating
  12. Filter Size 82 mm (Front)
  13. Dimensions (Ý x L) 3.46 x 5.36" / 87.8 x 136.2 mm
  14. Weight 38.45 oz / 1090 g
Sigma 45mm f/2.8 FE at B&H Photo | Adorama | Amazon ($549)
45mm F2.8 DG DN | Contemporary Main features:
  2. E-Mount Lens/Full-Frame Format
  3. Aperture Range: f/2.8 to f/22
  4. Soft, Smooth, Rounded Bokeh
  5. High-Speed AF with Stepping Motor
  6. Rounded 7-Blade Diaphragm
  7. Maximum Magnification 0.25x
  8. Macro Reproduction Ratio 1:4
  9. Minimum Focus Distance 9.45" / 24 cm
  10. Optical Design 8 Elements in 7 Groups
  11. Durable, Weather-Sealed Construction
  12. Filter Size 55 mm (Front)
  13. Dimensions (Ý x L) 2.52 x 1.82" / 64.0 x 46.2 mm
  14. Weight 7.58 oz / 215 g
_______________________
Sigma 14-24mm f/2.8 FE at B&H Photo | Adorama | Amazon ($1,399)
  2. Aperture Range: f/2.8 to f/22
  3. One FLD Element, Five SLD Elements
  4. Three Aspherical Elements
  5. Maximum Magnification 0.14x
  6. Macro Reproduction Ratio 1:7.3
  7. Minimum Focus Distance 11" / 27.94 cm
  8. Optical Design 18 Elements in 13 Groups
  9. Super Multi-Layer & Nano Porous Coating
  10. High-Speed AF with Stepping Motor
  11. Customizable AFL Button
  12. Rounded 11-Blade Diaphragm
  13. Weather-Sealed, Protective Front Coating
  14. Built-In Lens Hood
  15. Filter Size Gel Filter (Rear)
  16. Dimensions (Ý x L) 3.35 x 5.16" / 85.0 x 131.0 mm
  17. Weight 28.04 oz / 795 g
Sample images:
45mm 2.8 | 35mm 1.2 | 14-24 2.8
Sigma 45mm f/2.8
Sigma 35mm f/1.2
Sigma 14-24mm f/2.8
Jul 11, 2019 at 10:11 AM
scalanc2
p.1 #2 · p.1 #2 · Now in Stock: Sigma 35/1.2 Art, Sigma 45/2.8 and Sigma 14-24/2.8
I will as no current FE 35mm is top level at the moment.
Jun 24, 2019 at 09:07 AM
RoamingScott
p.1 #3 · p.1 #3 · Now in Stock: Sigma 35/1.2 Art, Sigma 45/2.8 and Sigma 14-24/2.8
Not interested in throwing out my back just for 35mm.
Jun 24, 2019 at 09:29 AM
AndrewNYC
p.1 #4 · p.1 #4 · Now in Stock: Sigma 35/1.2 Art, Sigma 45/2.8 and Sigma 14-24/2.8
I WANT A SIGMA-CRON NOT A SIGMA-NOCT! Give me some small nice f2s!!! Ahhhhhhh!
Jun 24, 2019 at 09:34 AM
realVivek
p.1 #5 · p.1 #5 · Now in Stock: Sigma 35/1.2 Art, Sigma 45/2.8 and Sigma 14-24/2.8
+1000
Jun 24, 2019 at 09:35 AM
Ayoul
p.1 #6 · p.1 #6 · Now in Stock: Sigma 35/1.2 Art, Sigma 45/2.8 and Sigma 14-24/2.8
It could be interesting.
I own both the Zony 35 1.4 and a very good copy of the Samy, but none of them fully satisfies me...
Jun 24, 2019 at 09:50 AM
Holger
p.1 #7 · p.1 #7 · Now in Stock: Sigma 35/1.2 Art, Sigma 45/2.8 and Sigma 14-24/2.8
I will preorder immediately.
phototiimo
p.1 #8 · p.1 #8 · Now in Stock: Sigma 35/1.2 Art, Sigma 45/2.8 and Sigma 14-24/2.8
I know everyone wants an f1.8 or f2, but it's possible this lens could be the high quality 35mm that the FE system needs. All the other options have major issues. The Sony Zeiss f1.4 has CA and onion ring issues and major problems with quality control, as does the Samyang f1.4. The Samyang and Sigma offerings do not have the best AF (certainly not in video mode or low light). The Sigma f1.4 has the welded on adapter which extends the balance of the lens even farther from the body and increases size with no optical advantage. I know many people don't care for the bokeh rendition of the 35mm f1.4 Sigma either.
Sigma's new lenses have shown much higher quality bokeh, more consistent and faster AF, somehow even more ridiculous levels of sharpness across the frame, better correction of aberrations, etc. As long as this lens isn't that much heavier than the 35mm or 28mm f1.4 ART lenses then I think it could be a great option. I for one would be perfectly fine to not have perfect sharpness from wide open, as long as the weight savings are there. Stopping down to f2 or f2.8 for ultimate sharpness is not a deal breaker for me, as long as bokeh and rendering is beautiful, the AF is fast, and the weight is reasonable. I do hope it features at least 11 aperture blades though, as nine blades in a fast and premium lens seems a little low after being spoiled by the GM series and its amazing bokeh.
Jun 24, 2019 at 10:00 AM
milkod2001
p.1 #9 · p.1 #9 · Now in Stock: Sigma 35/1.2 Art, Sigma 45/2.8 and Sigma 14-24/2.8
Wonder if it will be designed for L mount and glued with Sony E mount on rear or native FE lens.
Jun 24, 2019 at 10:09 AM
nupe009
p.1 #10 · p.1 #10 · Now in Stock: Sigma 35/1.2 Art, Sigma 45/2.8 and Sigma 14-24/2.8
I just ordered the 35 1.4 because it was on sale. It was down to $600 on B&H. The rumor about the 35 1.2 would explain the big price drop in the 35 1.4.
Jun 24, 2019 at 10:12 AM
vdo1
p.1 #11 · p.1 #11 · Now in Stock: Sigma 35/1.2 Art, Sigma 45/2.8 and Sigma 14-24/2.8
How about itís an APS lens....
Jun 24, 2019 at 10:18 AM
bjornthun
p.1 #12 · p.1 #12 · Now in Stock: Sigma 35/1.2 Art, Sigma 45/2.8 and Sigma 14-24/2.8
1.2 is both the max aperture and the weight in kilograms.
Jun 24, 2019 at 10:31 AM
BPsmith511
p.1 #13 · p.1 #13 · Now in Stock: Sigma 35/1.2 Art, Sigma 45/2.8 and Sigma 14-24/2.8
jahro wrote:
It's likely going to be huge. I'm wondering if Sony is planning to come out with a 35 1.8/2 FE within the next year... That with the 85 1.8 would be an amazing two lens kit.
The current Sigma FE lenses are already huge. I can't wait to see how this one turns out. Knowing Sigma it will look like a 200mm F2
Jun 24, 2019 at 11:19 AM
Tom K.
p.1 #14 · p.1 #14 · Now in Stock: Sigma 35/1.2 Art, Sigma 45/2.8 and Sigma 14-24/2.8
This would be a dream lens for me as long as it isnít obscenely huge. I shoot bands in very low light nightclubs and the 1.2 aperture would be phenomenal for me. I can get very close to the subjects in many cases. I am concerned about the potential size. Freakishly BIG will attract to much attention when Iím shooting in the club. I do look forward to this announcement.
Jun 24, 2019 at 11:22 AM
SpecFoto
p.1 #15 · p.1 #15 · Now in Stock: Sigma 35/1.2 Art, Sigma 45/2.8 and Sigma 14-24/2.8
I was very interested in the Sigma 35mm f1.4 because it was a bit smaller and had a 67mm filter size like my 24GM, FE 85mm and Batis 135mm. But reviews were less than stellar with most citing AF hunting issues, even in full daylight. (ended up with Batis 40mm). I hope yours is a good copy, but maybe Sigma decided to fix this and went all out with a f1.2 version replacement. It most certainly will be huge compared to yours and a lot more expensive.
Jun 24, 2019 at 12:48 PM
Jman13
p.1 #16 · p.1 #16 · Now in Stock: Sigma 35/1.2 Art, Sigma 45/2.8 and Sigma 14-24/2.8
Same. I couldn't resist it for $600. If others are interested, the sale is through today. Shows $649, but you can get another $50 off with the promo code YOUGO2BH.
Edit...mine just got here, and so far it looks like a winner. Focus in the limited testing I've done so far has been dead-on accurate, and it's quite sharp, even at f/1.4. It seems there's a bit of field curvature when stopping down (which is true of a lot of fast 35mms), such that the edges focused close up are actually sharper at f/1.4 than at f/2, though stopping down further brings things within the DOF.
If the f/1.2 version is even better, it'll be one heck of a lens.
Edited on Jun 24, 2019 at 02:30 PM · View previous versions
Jun 24, 2019 at 01:15 PM
blink310
p.1 #17 · p.1 #17 · Now in Stock: Sigma 35/1.2 Art, Sigma 45/2.8 and Sigma 14-24/2.8
This is great news!! Thanks for sharing.
Jun 24, 2019 at 01:48 PM
Ayoul
p.1 #18 · p.1 #18 · Now in Stock: Sigma 35/1.2 Art, Sigma 45/2.8 and Sigma 14-24/2.8
Given the fact that the 35 1.4 art was released 6 years ago, I expect this new lens to be better in every way.
Jun 24, 2019 at 03:06 PM
ftllens
p.1 #19 · p.1 #19 · Now in Stock: Sigma 35/1.2 Art, Sigma 45/2.8 and Sigma 14-24/2.8
Just saw this on SAR. Really excited. I don't mind the size at all and since it'll be "native" I can't imagine it being that much larger than the 40 1.4. Will pre-order as soon as it's listed!
I had an exceptional copy of the Zony 35 1.4 and I loved it except I wished it had cleaner bokeh and sharper with less aberrations. If the 35 1.2 is anything like their 40, then I will be so hyped.
Jun 24, 2019 at 03:08 PM
trogdon
p.1 #20 · p.1 #20 · Now in Stock: Sigma 35/1.2 Art, Sigma 45/2.8 and Sigma 14-24/2.8
Iíve got the old 35 ART in A mount, itís a good lens but I donít have a great copy of it (mine seems decentered on the bottom side of the image). Iíd be interested in this if they can keep the size reasonable.
Jun 24, 2019 at 03:31 PM
       2       3              17       18       end
       2       3              17       18       end
Username      Reset password
